Thread: 404a / OFN
    ROYHUNT's Avatar
    ROYHUNT Guest
    404a / OFN
    i recently went to a job where the customer had switched the machine on and ran it for 3 days with ofn in it instead of 404a. what can be done to save it?
    Aug 2008
    Baltics
    786
    Re: 404a / OFN
    Hello.
    Test the motor windings resistance, "high pot" - when it is cooled down, check oil level, make a short start with current measurement, if it is found that the motor had survived, complete all the necessary putting to work procedures on the machine.
    ROYHUNT's Avatar
    ROYHUNT Guest
    Re: 404a / OFN
    Thanks Yuri .
    The compressor was extremely hot.
    It was vacced out and then recharg but still extremely hot . would you expect the comp to be irreparably damaged
    Mar 2006
    belfast
    239
    Re: 404a / OFN
    if it was a new system you would expect the clixen or another overheat /overcurrent device to save the comp
    Oct 2004
    uk
    56
    193
    Re: 404a / OFN
    3 days would probably cause irreprable? damage to the windings. there is no cure. it would cause the oil to breakdown and spread around the system depending on the oil recovery method. dare i ask why it wasn't locked off?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: 404a / OFN
    Why did he?
    ROYHUNT's Avatar
    ROYHUNT Guest
    Re: 404a / OFN
    Thanks for the reply.
    It was switched back on after a pressure test, by one of the shop staff . They were told not to touch it by my colleague. I went there to repair the leak he found as he couldnt repair it there and then as it is in an airport and needed hot works permit to be issued first.
    He should have made it impossible to switch on though,
    once again
    many thanks
    roy
  1. Which system is better R 404A or R 717?
    By smpsmp45 in forum Refrigerants
    Last Post: 25-08-2011, 01:42 AM
  2. Trouble with 404A system...Please Help
    By wllmwallace in forum Commercial
    Last Post: 06-04-2009, 11:54 PM
  3. 404a high pressure?
    By flyboy3b in forum Trouble Shooting
    Last Post: 01-09-2008, 05:18 AM
  4. Hubbard 404a
    By evanso in forum Commercial
    Last Post: 07-09-2007, 09:29 PM
  5. R 404a
    By Samarjit Sen in forum Refrigerants
    Last Post: 07-08-2007, 06:35 PM
