Results 1 to 17 of 17
Thread: Brine Freezer
25-01-2010, 08:22 PM #1
Brine Freezer
Hi Everybody:
Someone has heard about a "brine freezer" i'm trying to find some information but i don't find nothing Someone could help me please.....
Luis Sandoval.
25-01-2010, 08:27 PM #2
Re: Brine Freezer
Hi Luis, Check this out
http://www.foodprocessing-technology...rostmark3.html
NormMy wife used to say you never listen to a word I say at least I think that what she said
25-01-2010, 11:59 PM #3
Re: Brine Freezer
hi all, about the question , brine freezers. when I was 20 years old I joined the merchant navy, working in the outward leg I worked in the engine room . on the homeward leg I was told that I was to be made up to 3rd fridge eng < my introduction into refrigeration< the ships where refrigeration cargo ships, the fridge consisted of a halls single piston comp running on co2 and brine was the secondary refrigeration my first impression was not conplymentary to ship or equipment, but we got home without sinking < this time< this was in 1968
26-01-2010, 12:23 AM #4
26-01-2010, 02:06 AM #5
Re: Brine Freezer
The brine freezers I am familiar with are usually a tank about 12 feet long and 8 feet wide with a center divider and a propeller to circulate salt brine around. One side has a flooded refrigeration coil of steel pipe and baskets of Crab or other seafood are set in with a hoist. You can hold about 0 degrees F and freeze very quickly.
Could not find a picture, but will look for one later.
27-01-2010, 05:30 PM #6
Re: Brine Freezer
so much thanks for your answers guys i have to compute a brine freezeer of 6 Tm/h with a flooded refrigeration coil somebody has any information for that ( books, files, drawing, diagramas, etc) i hope that you can help me.
Best Regards.
Luis.
17-02-2010, 08:55 PM #7
Re: Brine Freezer
Hi guys:
I still continue with this project and i have calculated tubes from flooded coil it's around 3980 m of tube of 1 1/4" but now i need to do the tube layout and i don't know how i should do this layout. somebody can give me some advices for this.
Best regards.
27-02-2010, 04:36 PM #8
Re: Brine Freezer
Hi guys!Brine is the chiller or the device that the working temperature is under 0 degrees Celcius!That devices uses liguids that can affort that temperatures!
27-02-2010, 04:53 PM #9
Re: Brine Freezer
luis The brine freezer in my plant has a seperate shell and tube chiller. The brine is pumped from the freezer through the chiller and returns to the freezer. C.D.
NH3 for me
28-02-2010, 09:33 AM #10
Re: Brine Freezer
Are you looking for slurry ice?
http://en.wikipedia.org/wiki/Slurry_iceIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
11-03-2010, 04:03 PM #11
Re: Brine Freezer
The brine freezer will be used to freeze fish someone has some information???
Luis
12-03-2010, 06:23 PM #12
Re: Brine Freezer
IS this what you're looking for?
http://www.pamref.co.za/flowice.htmlIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
12-03-2010, 06:25 PM #13
Re: Brine Freezer
12-03-2010, 07:39 PM #14
Re: Brine Freezer
Hi, luissandoval
are you looking for something like this...
not to much input data from you
Best regards, Josip
12-03-2010, 08:47 PM #15
Re: Brine Freezer
Looks like a steam train from Leonardo da Vinci
24-03-2010, 10:41 AM #16
Re: Brine Freezer
can a glycol based system used for making ice candies considered as a brine freezer?
26-04-2010, 10:20 PM #17
Re: Brine Freezer
hi guys what happen if i use pipe 1 1/4" of sch40 for this brine freezer because i've seen in some manuals that for pipes below of 1 1/2" have to be sch80 the conditions are:
Evaporating temperature : -23ºC
Discharge temperature: +35ºC
Refrigerant: NH3
Blast Freezer Within Freezer
By rickmor in forum Technical DiscussionsReplies: 4Last Post: 18-06-2009, 03:37 AM -
ice cream truck freezer
By GaryC in forum TransportReplies: 7Last Post: 06-12-2008, 02:19 AM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
Freezer compressor running 20 Hours/day
By rickcw in forum DomesticReplies: 12Last Post: 08-03-2008, 11:50 PM -
Trolley freezer & blast freezer
By smpsmp45 in forum NH3Replies: 0Last Post: 25-08-2007, 07:29 AM
