Results 1 to 16 of 16
Thread: Oil/lubrication Question.
21-01-2005, 05:33 AM #1
My apologies if this is in the wrong forum.
I will be building a refrigeration system for my PC. Pics can be found on www.silverplatinum.tk, under "Gallery" and "Xtreme Frosbite".
Now I will be using propane (R290) as a refrigerant. I have had a bit of a problem finding some cheap/small quantity oil for the system. But I managed to find some (today)
It is called Suniso Mineral Oil 3GS, which has a viscosity of SUS150, am I right? SUS 100 - SUS 150 is what I am after.
Now my two Questions:
1) Does 3GS=Sus 150?
2)What does add a charge of 10 psi static mean?
21-01-2005, 07:19 AM #2
Re: Oil/lubrication Question.
Regarding SUS versus 3GS or 4GS see
http://www.hydrobalance.com/MineralLubricants.htm
You need 3GS but why do you need oil anyway, compressors are normally prefileld.
Add refrigerant while standstill till given pressure or increase pressure after a vacuum in your system with R290 till 10 psi.
We have a special section "CPU Overclockers"It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
21-01-2005, 10:31 AM #3
The oil was burnt, otherwise I would not have made my work 2x harder.
I'll have to read up more static charging.
21-01-2005, 12:40 PM #4
Hi Dilan.
Peter has explained it perfectly.
Static pressure is the pressure inside a system when it is still,
After it was under vacuum and filled with R-290 up to the point when the gauges low side shows 10psi.
Chemi
21-01-2005, 06:00 PM #5
If the oil was burnt, then you have a problem.
Why was it burnt?
Hasn't it attacked the windings?
You will need to clean it and add a protector canister (AcidAway) in the oil and/or a burnout filter .It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
21-01-2005, 09:20 PM #6
Originally Posted by Dilan
Be careful to cleanup the compressor very well and to check the cause of oil burntEngineering, sciences, math, physics and my brain will generate "not responding " soon
21-01-2005, 11:43 PM #7
I will try get a pic of the OIL ASAP. The people I asked said the oil was burnt, ( I will kill him, if he is wrong).
Just another question, can anything bad happen from mineral oil, comming in contact with the atmosphere?
Edit - Peter, I tried looking at that site, but couldn't find out what the viscosity of 3gS was?Last edited by Dilan; 21-01-2005 at 11:47 PM.
22-01-2005, 08:43 AM #8
Any refrigeration grade oil when exposed to the atmosphere will attract moisture. Mineral oil is not as hygroscopic as esther oil but will still pick up moisture
22-01-2005, 07:14 PM #9
H.B. MINERAL LUBRICANTS
NAPHTHENIC (MINERAL) REFR. LUBRICANTS
H.B. naphthenic refrigeration oils are manufactured by Calumet Lubricants and packaged under strict quality controls in our ISO 9001 certified facility. These lubricants meet or exceed the specifications of most equipment manufacturers including:
General Electric Danfoss
Bristol
Copeland
Trane
Carrier (Carlyle)
White Consolidated
MINERAL REFR. OIL #3
(Calumet RO15)
Replaces 3GS or C-3
ISO Viscosity Grade 32 / 150 SUS @ 100°F
MINERAL REFR. OIL #4
(Calumet RO30)
Replaces 4GS or C-4
ISO Viscosity Grade 68 / 300 SUS @ 100°F
MINERAL REFR. OIL #5Replaces 5GS or C-5
ISO Viscosity Grade 100 / 525 SUS @ 100°F
REFRIG#3 MSDS
REFRIG#4 MSDS
REFRIG#5 MSDS
ORDERING DATAIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
23-01-2005, 08:25 PM #10
I will try get a pic of the OIL ASAP. The people I asked said the oil was burnt, ( I will kill him, if he is wrong).Engineering, sciences, math, physics and my brain will generate "not responding " soon
23-01-2005, 10:41 PM #11
Originally Posted by botrous
If you don’t want me to ask questions, I will refrain from doing so, I was under the impression that forums where a place of discussion, asking questions and meeting/interacting with people who have similar interests
On the other hand, thanks for the information Peter_1, you have been a help from the start.
Just confirmation, 3GS has a viscosity of Sus 150 @ 100°F?Last edited by Dilan; 23-01-2005 at 10:45 PM.
24-01-2005, 04:04 PM #12
Forum are places of discussions no doupt , and that what i was doing . . .
Surprised of why you thought like that . . . anyway i gladly appologies if my posts where in anyway a harm for you.
So please accpet my appologyEngineering, sciences, math, physics and my brain will generate "not responding " soon
25-01-2005, 04:53 AM #13
Sorry I came across very arrogantly, had a bad day.
After asking around, I have found out that Suniso 3GS would clog my evaporator at the temperatures I am running. So that is a shame.
I have to look out for a aklylbenzene oil, or some mineral oil that is rated to around -40°C.
25-01-2005, 10:45 AM #14
Here is a pic of the oil, does it look burnt to you guys?
I am not sure what type of oil that is, the compressor says CCL2F2 (which I am guessing is the refrigerant.
25-01-2005, 02:40 PM #15
Hi Dilan.
The refrigerant ccl2f2 is R-12.
You can not use it any more.
The oil looks used but not burnt.
POE is oil that can work with no problems in low temp but so is MIN oil.
Chemi
25-01-2005, 04:50 PM #16
the oil doesn't look too bad but the fruit certainly looks past it's sell by date !!
cheers
richard
Newbie with a question
By AcidSlasher in forum FundamentalsReplies: 4Last Post: 07-03-2006, 11:20 AM -
quizy type question thingy
By rbartlett in forum Chit Chat & Service StoriesReplies: 25Last Post: 06-02-2006, 09:22 PM -
A/C Question
By Latte in forum Air ConditioningReplies: 4Last Post: 24-08-2004, 08:19 PM -
Urgent, Kirchoff question
By Peter_1 in forum FundamentalsReplies: 4Last Post: 20-01-2004, 03:12 PM
