Results 1 to 2 of 2
Thread: grunaire hx inverter mini split
25-01-2010, 02:38 AM #1
i am having problems on a grunaire inverter system, coming up with a f1 error code,called the distributor and told me communication problem,sent indoor circuit board,still has same f1 code,please help
25-01-2010, 11:38 PM #2
Re: grunaire hx inverter mini split
Have you checked the cabling?
Grunaire Mini Split Operating PSI
By drose300 in forum Technical DiscussionsReplies: 11Last Post: 09-07-2010, 05:31 PM -
Anyone ever seen a 'dc inverter' split that has a conventional PSC cap?
By paul_h in forum Air ConditioningReplies: 4Last Post: 20-12-2009, 08:12 PM -
split inverter unsure of proper charge spec.. how to charge?
By cadillackid in forum Air ConditioningReplies: 4Last Post: 19-11-2009, 01:52 PM -
Mini split system heating, but not cooling well.
By tirider in forum Heat PumpsReplies: 7Last Post: 06-11-2009, 09:17 PM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM
