Results 1 to 12 of 12
Thread: Fujitsu AUY25RLD problem
23-01-2010, 08:29 PM #1
My air conditioner on the display blink EE EE. How to reset the device? Once I accidentally managed, the device has worked one time correctly. How do I get user manual and service manual in any form. Any help is appreciated because I have no alternative heating ;-)
24-01-2010, 11:28 AM #2
Re: Fujitsu AUY25RLD problem
When EE:EE is displayed on remote control , press “Energy Save” &
“Zone Control” buttons simultaneously for longer than 3 secs. The error
code will then be displayed on the LCD.
24-01-2010, 03:34 PM #3
Thanks for Your help, now we know more, the error code is 3, I do not know what that means, maybe someone has a list of errors ?
24-01-2010, 05:02 PM #4
E3= Return air thermistor short circuit
Hope this helps
Troy
28-01-2010, 03:52 PM #5
The problem is not resolved, I want to buy the service manual in any form.
28-01-2010, 05:38 PM #6
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Service manuals are not for sale. I have service manual, but I am not allowed to give it to no one who is not authorized from Fujitsu or their representatives.
Are you service engineer? In your profile it said Trader. Than, what is the point to obtain service manual when you don't have qualifications to use it.Last edited by nike123; 13-02-2011 at 01:21 AM.
28-01-2010, 06:00 PM #7
Have you disconnected and made sure that the room sensor on yours AC is indeed out of order (short-circuited - according to the code 3) ?
05-01-2011, 08:17 AM #8
Hi,I have some new problems with aircondition.
When I turn it on it works normally,it heats normally,
but then after a while on display starts to blink error
three times and then compressor turns off. Only fan keeps working and then again after a while the same problem with error on display appears.
06-01-2011, 03:25 PM #9
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
06-02-2011, 05:54 PM #10
[quote=nike123;216211]What is error number?
E:xx?
Hi,when I press to search for error it shows me zeros, four zeros and they blink all thw time! Can you help me with that? Thanx
13-02-2011, 12:28 AM #11
Tech Manuals here
http://www.fgeurofred.co.uk/default.asp?docId=12663
But, by the sound of it, you really need to call in a tech engineer to diagnose the fault and fix it.
13-02-2011, 01:23 AM #12
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
All zeroes mean that comunication between indoor and remote is faulty.
Fujitsu Multi problem
By BMS1 in forum Heat PumpsReplies: 15Last Post: 02-09-2010, 06:41 AM -
Fujitsu Problem
By msimeou in forum Technical DiscussionsReplies: 3Last Post: 29-01-2009, 04:06 AM -
Fujitsu ARY-A12LATN (problem on auto)
By pen_ster2002 in forum Air ConditioningReplies: 9Last Post: 03-12-2008, 12:56 PM -
FUJITSU Heating Problem
By mark171 in forum Trouble ShootingReplies: 13Last Post: 16-05-2008, 11:22 AM -
Fujitsu Problem
By tennern in forum Air ConditioningReplies: 22Last Post: 07-04-2007, 02:37 AM
