Results 1 to 12 of 12
    makar553's Avatar
    makar553 Guest
    Fujitsu AUY25RLD problem
    My air conditioner on the display blink EE EE. How to reset the device? Once I accidentally managed, the device has worked one time correctly. How do I get user manual and service manual in any form. Any help is appreciated because I have no alternative heating ;-)
    Aug 2008
    Baltics
    786
    Re: Fujitsu AUY25RLD problem
    When EE:EE is displayed on remote control , press “Energy Save” &
    “Zone Control” buttons simultaneously for longer than 3 secs. The error
    code will then be displayed on the LCD.
    makar553's Avatar
    makar553 Guest
    Thanks for Your help, now we know more, the error code is 3, I do not know what that means, maybe someone has a list of errors ?
    Jan 2009
    london
    52
    E3= Return air thermistor short circuit
    Hope this helps
    Troy
    makar553's Avatar
    makar553 Guest
    The problem is not resolved, I want to buy the service manual in any form.
    Split Croatia
    6,151
    Quote Originally Posted by makar553 View Post
    Service manuals are not for sale. I have service manual, but I am not allowed to give it to no one who is not authorized from Fujitsu or their representatives.
    Are you service engineer? In your profile it said Trader. Than, what is the point to obtain service manual when you don't have qualifications to use it.
    Aug 2008
    Baltics
    786
    Have you disconnected and made sure that the room sensor on yours AC is indeed out of order (short-circuited - according to the code 3) ?
    makar553's Avatar
    makar553 Guest
    Hi,I have some new problems with aircondition.
    When I turn it on it works normally,it heats normally,
    but then after a while on display starts to blink error
    three times and then compressor turns off. Only fan keeps working and then again after a while the same problem with error on display appears.
    Split Croatia
    6,151
    What is error number?
    E:xx?
    vlado666666's Avatar
    vlado666666 Guest
    [quote=nike123;216211]What is error number?
    E:xx?
    Hi,when I press to search for error it shows me zeros, four zeros and they blink all thw time! Can you help me with that? Thanx
    May 2006
    Sussex
    362
    Tech Manuals here
    http://www.fgeurofred.co.uk/default.asp?docId=12663
    But, by the sound of it, you really need to call in a tech engineer to diagnose the fault and fix it.
    Split Croatia
    6,151
    All zeroes mean that comunication between indoor and remote is faulty.
  1. Fujitsu Multi problem
    By BMS1 in forum Heat Pumps
    Last Post: 02-09-2010, 06:41 AM
  2. Fujitsu Problem
    By msimeou in forum Technical Discussions
    Last Post: 29-01-2009, 04:06 AM
  3. Fujitsu ARY-A12LATN (problem on auto)
    By pen_ster2002 in forum Air Conditioning
    Last Post: 03-12-2008, 12:56 PM
  4. FUJITSU Heating Problem
    By mark171 in forum Trouble Shooting
    Last Post: 16-05-2008, 11:22 AM
  5. Fujitsu Problem
    By tennern in forum Air Conditioning
    Last Post: 07-04-2007, 02:37 AM
