Results 1 to 16 of 16
22-01-2010, 01:54 PM #1
R407C and R410a for low temperature
Dear All!
What do you think about using R407C and specially R410a for low evaporationg temperatures (-35°C)?
Daikin both for Condensing units for low and medium temperatures...
22-01-2010, 02:03 PM #2
22-01-2010, 04:55 PM #3
Re: R407C and R410a for low temperature
To everything there is a season, a time for every purpose under heaven . . . a time to weep, and a time to laugh; a time to mourn, and a time to dance . . .
There is a refrigerant for low temperature
There is a refrigerant for high temperature.
25-01-2010, 01:26 AM #4
I just get my Certification for R-410
25-01-2010, 07:51 AM #5
As I am pretty new in this bussines, can you provide more infroamtions...
25-01-2010, 08:13 AM #6
25-01-2010, 03:11 PM #7
25-01-2010, 04:24 PM #8
25-01-2010, 08:49 PM #9
28-01-2010, 07:38 PM #10
Sorry for the mistake... I think of R410A as a single refrigerant because I do not blend it myself. I blend R410A and R134A to achieve R407C and R407D.... Soon hope to start blending proprietary mixes that my manufacturer uses.
11-02-2010, 11:32 AM #11
Hi!
-35° evaporator/cabinet is used for deep-freezed goods in markets.
There are 2 versions of units with R410a:
1) unit only for deep-freeze and different unit for medium temperatures- It has same components but electronic part is different. Note: in smallest units is only one compressor (min Te=-45°C) . Commercial name: ZEAS
2) outdoor unit for medium temperatures + booster compressors for Te=-35°C-everything connected in same refrigerrant circuit. On this system are connected indoor units whitch are using heat recovery during winter. System is dimensioned for required refrigeration and cooling demand of the space. Commercial name: Conveni Pack
I heard some comments that R410a is "not stable" at so low temperature, but as far as I saw installed systems are working perfectly!
11-02-2010, 03:19 PM #12
11-02-2010, 03:29 PM #13
01-01-2011, 09:39 PM #14
Units that are available in the USA with R410A are Air Conditioning Units and Heat Pumps. I do not know of any manufacturer making R410A available for Refrigeration applications but a chiller application is probably available. Factory done Low Temperature units are being made with R404A and R507. I have seen and used R22 as a Low Temp Application but the compressor head needed a Demand Cooling switch to cool compressor head. Here in the USA I just haven't heard of R410A being used this way and I would think it was more possible with R407C. But the Compression Ratios with R410A at Low Temperatures I would think we would see something worse than what was going on with R22 at these temperatures.
19-01-2011, 09:15 AM #15
Ditto down here in NZ, the only time I have seen R22 used as a low temp refrigerant successfully is in the type 3 Bitzer open drive comps with water cooled heads, think 407 would be a slighter lesser nightmare than 410 in low temp work but only just due to the wide glide charcteristics
19-01-2011, 08:28 PM #16
410 being used for some time inlow temp situations on frigoblock units have very little problems as far as 407c goes i dont rate the refrigerant at all i have more problems with 407 than anything else my question is why was 410 developed when 404 is available is it efficientcy?
What gauges can i use for R407c????
By luke.180 in forum RefrigerantsReplies: 15Last Post: 29-01-2010, 07:50 PM -
R410a recommended training??
By matt p in forum RefrigerantsReplies: 9Last Post: 25-01-2010, 03:55 AM -
Pipes to large for R410a??
By Spanglishsparky in forum Technical SpeculationsReplies: 6Last Post: 09-05-2009, 12:57 AM -
Pumpig R404a; R410a; R407c
By Konstantin in forum RefrigerantsReplies: 2Last Post: 08-11-2007, 05:56 PM -
R410A - state of art
By MrReds in forum RefrigerantsReplies: 2Last Post: 04-03-2007, 10:56 PM
