    Jan 2009
    INDIA
    40
    propane V/s propylene
    can any body tell me that whether propane or propylene will be a better refrigerant for using in a system at -35 degree evaporating temperature??
    Aug 2008
    California
    28
    Re: propane V/s propylene
    Assuming -35F and 90F condensing temp
    R-1270 R-290
    Evap -34 -34 F
    Cond 90F 90 F
    Liquid Enthalpy -13.206 261.59 btu/lb
    Vapor enthalpy 97.731 368.2 btu/lb
    Vapor entropy 1.4085 1.3649 BTU/lb-R
    Suction pressure 23.62 18.562 PSIA
    Condening press 199.8 165.58 PSIA
    Compression ratio 8.46 8.92
    Refrigeration effect 110.937 106.61 btu/lb
    Mass flow rate 108.1695 112.5598 lb/hr/ton
    Ideal Compression
    Discharge enthalpy 143.61 141.35 btu/lb
    Compressor work 45.879 43.15 btu/lb
    4962.71 4856.96 btu/hr/ton
    Efficiency 1.95 1.91 hp/ton
    Ideally propane is sightly better, The compression ratio of propane is higher than propylene so the compressor efficiency is lower. Infact they are almost identical.
    You will have to look at the compressor efficiency curves to get a better answer.
    Aug 2008
    California
    28
    Sorry my post killed my formatting
    Jan 2006
    Croatia
    63
    2,136
    Hi, Dacosta
    ... you can always edit your post and change formatting to make it easier for reading
    Best regards, Josip
    Aug 2008
    California
    28
    Thanks i can edit now but it still takes out all my spaces to put it into nice column like format.
  1. propylene refrigerant criteria
    By zhouweidl in forum Hydrocarbons
    Last Post: 30-07-2009, 01:01 PM
  2. DIY Install ~ R290 (Propane)
    By Makeit go Right in forum Air Conditioning
    Last Post: 23-09-2007, 10:34 PM
  3. Propane Refrigerator Conversion
    By zolar1 in forum Refrigerants
    Last Post: 04-02-2007, 03:42 AM
  4. propane compressor suction drum
    By Ahmed_LNG in forum Refrigerants
    Last Post: 01-01-2006, 08:01 AM
  5. propane compressor suction drum
    By Ahmed_LNG in forum Trouble Shooting
    Last Post: 30-12-2005, 06:08 AM
