Results 1 to 19 of 19
15-01-2005, 06:11 PM #1
extra cooling on domestic refrigerator
Firstly, I am not a refrigeration engineer but I would like to improve the efficiency of a LEC domestic refrigerator. This is an A rated unit which I have on a Narrowboat and I am trying to cut down on the amount of electricity it uses as it all comes from my battery bank.
I was intending to improve the insulation by adding 25mm of expanded polystyrene to the sides and top of the cabinet. In addition to this I was planning to blow cool air from the boat bilges over the condenser at the back of the unit.
Do you think I would achieve any savings by doing this?
regards Brian on NB Harnser
15-01-2005, 06:29 PM #2
Re: extra cooling on domestic refrigerator
It won't help because at LEC, a company with a name, they designed it already with the greatest efficiency and blowing wind from the bilges over the condenser will perhaps make that the unit will run outside the design conditions (too low condensing pressure)
By the way, is the air from the bilges not too salty?
Arent' the battery charged while engine is running?Last edited by Peter_1; 15-01-2005 at 06:36 PM.
15-01-2005, 06:34 PM #3
As Peter said , blowing air threw the condenser may cause too low condensing pressure (mostly out of the design) .
Question , is it an absorption or compression cycle ?
If it's an absorption you can manage it to work with propane or butane combustion . . . send the specifications of the system and we will see how we can helpEngineering, sciences, math, physics and my brain will generate "not responding " soon
15-01-2005, 06:59 PM #4
Originally Posted by botrous
15-01-2005, 08:09 PM #5
In that case, the only solution, is getting an absorption unit and your problems are over.
In a second thought, why not use one of those mini-bars.
They have a compressor 1/12 HP.
Also less weight on the boat
Good luck any way you decide.
Chemi
15-01-2005, 09:32 PM #6
The best way is to get an absorption mini bar , it's more effective and can work with heat source , maybe if you have good techncian they can make you the system work with heat from the yacht engine , and it's silent .... no noise in the yacht room
15-01-2005, 06:57 PM #7
Originally Posted by Peter_1
Yes the batteries do charge from the engine but sometimes we are moored up for a couple of days. The fridge uses about 36 ah per day at 24 volts DC via a 240 VAC Inverter. That is about a quater of the battery capacity.
Brian
Propane Refrigerator Conversion
By zolar1 in forum RefrigerantsReplies: 26Last Post: 04-02-2007, 03:42 AM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM -
Regulation of cooling capacity
By npaisnel in forum DomesticReplies: 13Last Post: 08-02-2002, 11:22 PM -
Domestic refrigerator coolant data
By Paul in forum FundamentalsReplies: 2Last Post: 13-10-2001, 10:31 AM
