Thread: My fridge is not working
18-01-2010, 10:46 PM #1
Sorry to hijack this post but couldn't work out how to start a new thread.
I have read loads of good stuff on here and thanks guys it was really helpful.
My problem is the fridge stopped getting cold - Hotpoint Iced diamond frost free. I took the advice on here and defrosted it but only waited 12hrs but it kicked off and hey presto got cold again. However it only lasted 2 days and started getting warm again. I decided to do as told on here and turned it off for 48hrs switched it back on and great it was working again. Problem is again after 2 days it has started to cool down again and looks like it is going again.
Any more ideas is the thermostat on its way out, is it worth getting an engineer out or is it ready for the skip.
18-01-2010, 11:00 PM #2
19-01-2010, 08:27 PM #3
Re: My fridge is not working
Definitely a defrost problem, 95% certain to be the timer.
Repair or replacement? It depends on age and condition of the cabinet, also whether you might have a problem getting the same size FF to fit a particular space?
Try calling one or two local repairers. Tell them that you are quite sure you need a new defrost timer, give them the details of the cabinet, and ask them for a quote (based on timer replacement). This should help you to decide.
20-01-2010, 03:51 AM #4
either way its worth repairing,could be timer,defrost termination stat,over temp safety stat,defrost heater or a broken wire.get someone half reputable who carries stock in their vehicle but i doubt they would have a heater on board.
good luckmmm to beer or not to beer...........lets drink breakfast
21-01-2010, 08:40 PM #5
Thanks for your posts I will contact a local engineer with your advice
21-01-2010, 08:48 PM #6
OK good luck
21-01-2010, 10:18 PM #7
It sounds like deffrost problem,after you run it for 2 days,check back wall if you see ice build up,that your verification of deffrost issue,next find deff timer,should be in the bottom ofm unit by kickplate,use small flat screwdriver tu turn the dial on timer,til you hear a click,it is now in deffrost lesson for sounds of water dripps hitting a hot heater.if you hear it ,replace timer if not it could be bimetal deffrost termostat or heater.I hope this was helpful.
Hotpoint Fridge Freezer Model 8595 (frost free) Freezer ok but fridge not working
By rabb5it in forum DomesticReplies: 2Last Post: 08-01-2010, 11:41 AM -
indesit ba13s fridge is not working right and freezer slighly frosting up
By no_mercy in forum RefrigerantsReplies: 0Last Post: 11-10-2009, 02:38 PM -
Whirlpool ARG 918WP (int F/F) Power on, but neither fridge or freezer working
By malwrx in forum DomesticReplies: 20Last Post: 14-06-2009, 05:51 PM -
Zanussi Fridge Freezer not working after moving
By Becca in forum DomesticReplies: 4Last Post: 15-06-2008, 09:42 AM -
is my fridge working properly?
By vincec in forum Trouble ShootingReplies: 1Last Post: 15-01-2002, 09:55 PM
