19-01-2010, 06:39 PM #1
How Can decrease the compressor capacity
I Have compressor which capacity 46.2 Kw , I need decrease the capacity to 42.6 Kw to matching with evaporator which capacity 42.6 Kw . What can I do ??
19-01-2010, 07:31 PM #2
Re: How Can decrease the compressor capacity
You dont need to do anything.
Your compressor is capaity is 8% more.
Its fine.
capacity will decrease as evaporating temp. will drop.
20-01-2010, 01:23 AM #3
As c-c says, it could probably be left well alone.
If you are concerned about matching & balancing, then you could look into installing a service valve in the suction line between evap & compressor. Set the valve during first operation, if required, then leave it alone after that.
Trimming of the evap can also be performed by backing off on the evap fan speed.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
How to decrease head pressure for an existing system?
By david2008 in forum FundamentalsReplies: 12Last Post: 30-07-2008, 09:46 PM -
R507 efficiency decrease verses R12
By Chris Moser in forum RefrigerantsReplies: 7Last Post: 28-07-2007, 02:03 PM -
Decrease of the viscosity oil with hydrocarbons mix...
By mebluna in forum System OptimizationReplies: 2Last Post: 27-04-2007, 04:54 PM -
Decrease room/start temperature
By kappl01 in forum Air ConditioningReplies: 9Last Post: 15-04-2007, 10:51 PM
