Results 1 to 21 of 21
Thread: Tricool
19-01-2010, 01:57 PM #1
Tricool
Anyone got access to these manuals as we have a N1 fault and can't clear it..
19-01-2010, 02:57 PM #2
Re: Tricool
Have you tried contact them?
http://www.tricool.com/local_contact.htm
19-01-2010, 03:25 PM #3
Re: Tricool
You could try ICS technical on 02380527346.
Tutto il Mondo e un Paese
19-01-2010, 03:40 PM #4
Re: Tricool
We have tried both (they are the same as ICS)
They are completely useless. Don't ever get back, full of "ERR haven't got that to hand..we'll phone you back."
They are the absolute worst Manufacturer for technical assistance
primarily because they want all the work themselves and just ignore any request..we know we've been here before with them
19-01-2010, 04:20 PM #5
Re: Tricool
Woooooooooopss.........
Didn't Know you have "relations" with them....
19-01-2010, 05:09 PM #6
Re: Tricool
Does it have the Carel PCo controller? Perhaps a search for this type of controller will help, or maybe someone can help you with faults for them instead? If not some details on the chiller and perhaps one of the brainiacs here can help?
19-01-2010, 06:12 PM #7
19-01-2010, 07:53 PM #8
19-01-2010, 08:16 PM #9
Re: Tricool
Some small chiller manufactures use a Carel IR controller which indicates:
n1 = The compressor requires maintenance: the total running hours of the
compressor (direct parameter c9) has exceeded the setting of the timer
treshold for maintenance warning
Hopefully more helpful than previous post
19-01-2010, 10:16 PM #10
20-01-2010, 11:39 AM #11
Re: Tricool
hello multisync, can you please provide the serial number and model number of the unit in question and i will see what i can do for you,
regards croc
20-01-2010, 01:02 PM #12
21-01-2010, 06:55 AM #13
Re: Tricool
Hi Multi,
VRV III is right, he has just jogged my memory, I have the alarms for a Ciat chiller which must use the same controller, if you go to C9 ( compressor one hour counter )and then press the up and down buttons simultaneously you will clear it.
I would attach the manual but have not got a clue how to as the file is too large.
CheersTutto il Mondo e un Paese
21-01-2010, 07:11 PM #14
Re: Tricool
Thanks guy's all sorted. Our engineer spoke to a guy called simon at Aquacool who was really helpful.
ICS on the other hand are useless!!
21-01-2010, 10:06 PM #15
21-01-2010, 11:52 PM #16
Re: Tricool
I believe you were correct and it's something to do with 'maintenance'.
Our engineer rang this Simon (might not be correct name btw) and he talked him through the reset. The N1 rang a bell with us and looking back we had the same fault code but the engineer who attended then has long since left.
Boss emailed ISC back in 07 asking for a manual or assistance and guess what: They never replied
ICS are useless!!!!!
22-01-2010, 02:04 AM #17
Re: Tricool
I really like the earlier comment on fault code description, "new one required " will program that into industrial systems PLc and computer scada systems for a laugh, and watch the accountants reactions.
22-01-2010, 03:00 PM #18
22-01-2010, 03:07 PM #19
10-08-2011, 06:50 PM #20
10-08-2011, 07:42 PM #21
Re: Tricool
Anyone needing tricool info should find Aqua cooling more helpfull
All ex tricool white & blue colour, nice bunch
Top engineers Simon B & Mark E, now own & run the showIf the World did not Suck, We would all fall off !
