Thread: Co2 - water
19-01-2010, 10:56 AM #1
Co2 - water
Hi !
Hapy new year for every one !!
I have a question,
Do you know if the use of CO2 in cascade applications must be necessarily anhydrous ?? Why
IF yes, what's the tolerance of water in CO2
Best regards
19-01-2010, 06:15 PM #2
Re: Co2 - water
hi ced
sry but cant show you the url in the forum...
you have to see on the web-site from danfoss.
refrigerants-> co2-green technology->
industrial refrigeration co2 applications-> site 7
should explain your question...
kind regards
19-01-2010, 06:52 PM #3
Re: Co2 - water
^^ Tom 80 ^^
URL for the link offered by Tom
http://www.danfoss.com/BusinessAreas...erants/CO2.htmBrian - Newton Abbot, Devon, UK
19-01-2010, 06:58 PM #4
Re: Co2 - water
big thx @ brain
maybe i can post soon too
19-01-2010, 07:19 PM #5
Re: Co2 - water
Yep, don't worry you'll get there.
You can always type out a URL with the odd space in it such as...
www . refrigeration-engineer.com
Then people can cut and paste if the wish.Brian - Newton Abbot, Devon, UK
22-01-2010, 08:34 AM #6
Re: Co2 - water
Thanks !
But do you know if it's possible to put CO2, for exemple with high level of water (100 PPM) above the maximum solubility limit (22 PPM) and dry it after with filter driers !
Is it to late ! The POE oil is it rapidly contamined etc ...
22-01-2010, 11:03 PM #7
Re: Co2 - water
then just one advice...
wen your system is contamined:
co2 out... clean your system... dry it (vaakum) and refill again...
otherwise you will have a lot more of problems with this unit...
Hoshizaki Ice Maker
By Abe in forum Legal-Business-MarketingReplies: 19Last Post: 01-05-2010, 03:27 AM -
Fact or Fiction
By david.findlay in forum FundamentalsReplies: 40Last Post: 09-03-2009, 06:19 PM -
Modifying aricond. for heating, cooling and hot water
By kimusabi in forum Technical DiscussionsReplies: 3Last Post: 10-10-2008, 07:28 AM -
open cycle R718 A/C that also provides high purity water?
By star882 in forum Technical SpeculationsReplies: 7Last Post: 27-07-2006, 04:18 AM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM
