Thread: Carrier Split Type
18-01-2010, 07:08 AM #1
Carrier Split Type
Hi There,
Is there anybody could give me an advise what would be the root cause of our Carrier split Type Aircon 5TR. We have 46 unit Carrier split type in our plant, after the commissioning we encountered 4 unit all 5TR's which the compressor are rondomly busted. Now the supplier already replaced 4 times in a row. We already replaced the whole ourdoor unit but the problem still recurring.
Your suggestion is much appreciated.
Thank you,
Mik
18-01-2010, 11:10 PM #2
Re: Carrier Split Type
Poor installation.
Electrical problems.
Poor installation.Brian - Newton Abbot, Devon, UK
23-01-2010, 04:01 PM #3
hi mik, how long is the pipe run , are the units with the duff compessors farther away than the ones that are ok?
23-01-2010, 04:34 PM #4
Systems with crossed pipework and or wiring.
23-01-2010, 09:16 PM #5
yes monkey spanners, I have seen many a balls ups with that , but I was thinking in this job many units they arnt all going to bethe same meters away and a lot of contractors put these units where ever they can and lots of times they are more than the recemended meterage conclusion= the compressors are not getting oil return
simple way for cleaning A/C split type
By refri_holic in forum Air ConditioningReplies: 12Last Post: 17-09-2009, 10:18 AM -
Carrier Split Heat Pump Systems
By Freecool in forum Heat PumpsReplies: 7Last Post: 02-01-2009, 06:17 PM -
Help identifying carrier HiWall dom. split
By paul_h in forum Air ConditioningReplies: 4Last Post: 12-12-2008, 09:12 AM -
the carrier split draw amper more than notmal
By karimihassan in forum Air ConditioningReplies: 5Last Post: 19-08-2007, 12:20 AM
