17-01-2010, 08:48 PM #1
DX capacity lower than condensing unit
I have DX unit which capacity 30.8 Kw install with condensing unit which capacity 39.3 Kw . DX capacity lower than condensing unit Is this a problem ?? What's this problem ??
17-01-2010, 08:50 PM #2
I have DX unit which capacity 30.8 Kw install with condensing unit which capacity 39.3 Kw . DX capacity lower than condensing unit Is this a problem ?? What's this problem ?? how can repair this problem??
17-01-2010, 08:57 PM #3
Re: DX capacity lower than condensing unit
What is DX unit, water cooler, air evap?
17-01-2010, 09:10 PM #4
Dear mad fridgie's DX mean Air Handling Unit (AHU) Air evp.
17-01-2010, 09:20 PM #5
Air handling unit capacity lower than condensing unit
I have Air handling unit which capacity 30.8 Kw install with condensing unit which capacity 39.3 Kw . Air handling unit capacity lower than condensing unit Is this a problem ?? What's this problem ?? How repair this problem??
17-01-2010, 09:29 PM #6
No real problems, the TD will be a bit bigger, which will dry the air a little more. Equalibrium will be reached.
Vrv
By tgoonter in forum Air ConditioningReplies: 4Last Post: 11-01-2011, 06:25 AM -
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 12:39 PM -
Condensing Unit
By marksmith970 in forum CommercialReplies: 4Last Post: 13-08-2008, 10:17 PM -
Replacement fo CO2 Bulk Tank refrigeration unit
By pabs_ref in forum CO2Replies: 31Last Post: 28-11-2006, 10:32 PM -
Matching Evaporator with Condensing Unit
By Abe in forum Technical DiscussionsReplies: 12Last Post: 25-07-2001, 08:57 AM
