Thread: Cool Gas Defrost
17-01-2010, 02:05 AM #1
Cool Gas Defrost
Hi everyone. I am working on a masterbuilt commercial freezer. It has a cool gas defrost. Does anyone have any ideas why there may be such a large amount of frost on the ceiling by the evaporator? Everything seems to be sealed well and the door is tight. I havent really gotten into it yet, but I suspect the unit is in defrost too long. any suggestions? Thanks - Jed
17-01-2010, 07:26 AM #2
Re: Cool Gas Defrost
Frost on the ceiling is from air entering. Replace the door gasket. Look for other places where air can enter.
Cool gas defrost or hot gas defrost?
17-01-2010, 09:07 AM #3
You could also have a problem with the insullation integrity of the coolroom panel, if there is moisture in the panel it will stay at room temp, when the evap goes into defrost and steam is released it will re-condense and freeze on the coldest area close to the unit in your case the ceiling. But at the end of the day the moisture has to be coming from outside the freezer, maybe a plastic air curtain would help.
Toshiba RAV SM/SP1400 defrost problem
By SteinarN in forum Heat PumpsReplies: 11Last Post: 20-02-2008, 04:25 PM -
No Power for Defrost Timer Motor
By kln in forum DomesticReplies: 6Last Post: 21-01-2008, 08:22 AM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM -
Hot gas defrost vs Electric defrost
By herdian in forum IndustrialReplies: 19Last Post: 13-08-2007, 11:25 PM
