Results 1 to 30 of 30
Thread: DX GSHP problems
17-01-2010, 05:17 PM #1
Re: DX GSHP problems
The refrigerant mass was checked a few weeks ago, but i am not sure that it was done properly, by the tecnician.
there is is on the evaporator suction, but not at the TXV.
There is no glycol/water since it is DX
17-01-2010, 07:51 PM #2
17-01-2010, 08:03 PM #3
18-01-2010, 12:29 AM #4
Again, please.
GSHP = ground-source heat-pump, no? So you're going DX directly implanted in the ground, not the conventional circulating loop system.
There should be temp sensor somewhere - in the ground, otherwise you'll not be able to work out what is going on.
Could your ground temp have really dropped so low? I'd wonder about that.Last edited by desA; 18-01-2010 at 12:34 AM.
Carrier 30XA Liquid chiller Problems
By Ed Burris in forum CommercialReplies: 7Last Post: 13-08-2010, 08:12 PM -
2.5 specific Dx gshp heat exchanger questions
By Riggerjack in forum Heat PumpsReplies: 14Last Post: 25-01-2009, 11:42 PM -
Oil problems with a dual temperature pack.
By Chunk in forum Supermarket RefrigerationReplies: 33Last Post: 11-09-2008, 03:29 AM -
Oversized Liquid Recievers?? Problems??
By nickjh in forum FundamentalsReplies: 12Last Post: 12-06-2007, 07:54 AM -
Oil return problems
By Peter_1 in forum IndustrialReplies: 37Last Post: 23-08-2004, 11:30 PM
