    prg281's Avatar
    prg281 Guest
    heat exchange unit won't stop
    Hello,
    I've got a HEIL HHP060 heat exchange unit outside that won't stop. The air blower inside follows the thermostat's command but it looks like the compressor keeps running; I've waited for more than 2hours and it just keeps running.
    It sounds like a contactor is stuck but based on the electrival diagram posted in the unit the contactor is whithin a capacitor. Is this possible and if so how can I test the capacitor to find out if it went bad? My ohmeter shows that all three connections of the capacitor are connected which I didn't expect if a contactor is embedded.
    I'v swaped out the thermostat just in case but that didn't help.
    Any suggestion? Am I focusing on a wrong issue?
    Aug 2008
    Baltics
    786
    Re: heat exchange unit won't stop
    Clearly - welded contact in the relay.
    Relay is inside of the indoor unit.
    prg281's Avatar
    prg281 Guest
    Thanks Yuri.
    Is there a voltmeter / ohmmeter test i could perform to confirm the failure?
    3,856
    If the relay is on but has no power feed from the thermostat to the coil then its stuck in, the relay is not in the capacitor.
    Your outdoor unit could have a short on it if the relay is off and its still running, (maybe fan running but not at full speed?)
    Best to turn it off at the disconnect and get a tech to look at it.
    Aug 2008
    Baltics
    786
    Supply input's resistance of any unit like this is hundreds/thousands ohms, now there should be only few ohms. Find the relay and check if this version is true.
    If yes,you may try to knock , carefully, at the relay, but better change it, and find out what had caused the too high current that had made the relay's contact stuck.
    prg281's Avatar
    prg281 Guest
    Smile Re: heat exchange unit won't stop
    Replacing the relay fixed it!
    Thanks again Yuri.
    Regards,
  1. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  2. First post, please be nice, prob with heat mode
    By back2space in forum Air Conditioning
    Last Post: 28-06-2009, 09:18 PM
  3. LG heat pump problem
    By back2space in forum Heat Pumps
    Last Post: 01-02-2009, 11:23 PM
  4. Super efficient, low carbon footprint, etc etc - ideas?
    By Makeit go Right in forum Air Conditioning
    Last Post: 05-12-2007, 05:56 PM
  5. heat exchanger for small chiller
    By star882 in forum Fundamentals
    Last Post: 30-01-2007, 12:06 PM
