Thread: Fault Diagnosis Flow Chart
13-01-2010, 07:01 AM #1
I am looking for a flow chart to put on the side of a cold room that helps the user decide whether or not to call me out at 0300 am. This is a fairly standard cold room with Run and Back up systems so in theory should anything go wrong the second system comes in and the problem can be solved in normal working hours! Somehow this has been lost in translation!! I am thinking a nice simply flow chart would be good. I have had a couple of goes but don't seem to be getting anything that looks helpful. CAN ANYONE HELP!!!
"It's better to remain silent and be thought a fool than open ones mouth and remove all doubt"
13-01-2010, 08:12 PM #2
Re: Fault Diagnosis Flow Chart
Without knowing exactly how your system operates it is a bit difficult for us to write up a chart for you.
Try writing down how you expect the system to work and what happens during fault conditions.
With the list in front of you it should be able to develop a chart from that.
Most 'office'type software has flow chart tools built in so maybe have a try with that too.
edit: Came across this, below, which might help you develop yours...
http://whqlibdoc.who.int/hq/2002/WHO_V&B_02.31.pdfLast edited by Brian_UK; 13-01-2010 at 08:22 PM.
14-01-2010, 03:54 AM #3
Blueboy keep it basically basic. Like door open, yardy yardy. Otherwise you will have client creating system havic, usually in the middle of the night. And they will deny touching anything, which will create a real can of worms for you.
magoo
20-01-2010, 09:01 AM #4
Just tell them to ask themselves one simple question before calling.
IS THE CHILLER COLD? Yes - don't call the engineer untill the morn. No - call the engineer. Easy.
Flow Rate through Fan Coil Unit
By deepu in forum Air ConditioningReplies: 4Last Post: 21-07-2009, 06:42 AM -
Capillary Tube Characteristics
By Chef in forum FundamentalsReplies: 9Last Post: 10-03-2009, 01:03 PM -
Nice A/C diagnose flow chart
By nicolacozma in forum Chit Chat & Service StoriesReplies: 4Last Post: 21-01-2009, 09:28 AM -
Split unit sensor explanation fault diagnosis?
By karl957 in forum Air ConditioningReplies: 8Last Post: 04-01-2009, 05:28 AM -
Fault with Tango cassette
By airefresco in forum Air ConditioningReplies: 8Last Post: 19-09-2007, 08:42 AM
