Results 1 to 18 of 18
    Jan 2010
    Australia
    10
    Daikin split compressor noise
    What sound is the compressor suppose to make when it is operating?
    Is it a high pitched whine sound? like "eeeeeeeeeeeeeeeee"
    Jan 2008
    Manchester, Uk
    57
    Re: Daikin split compressor noise
    Hahaha......i have one that goes......boom de boom de boom de boom!
    Aug 2009
    east anglia
    49
    95
    15
    I take it this is an inverter type.
    how old ?
    gas type?
    etc
    as long as it dont go zzzzzzzzzzzzzzzz think you will be ok
    Jan 2010
    Australia
    10
    Quote Originally Posted by croc1774 View Post
    how old ?
    gas type?
    etc
    It's a few days old, Daikin FTXS80H H series 8kw. It uses R410A. Having another listen it makes a sssssssssssss hissing sound I can hear from 3 floors down where I check my mail. After about 5 hours the sound stops, which I take it means it has cooled the lounge room down to the set point temperature.
    Aug 2009
    east anglia
    49
    95
    15
    Hi CTN, im guessing its quit warm were you are at the moment?
    Sounds normal to me my friend.
    If it is hot there, then leave it on over night at a reduced temp so it doesnt have to work so hard.
    regards
    Jan 2010
    Australia
    10
    At my parent's place, there's 2 splits and they are no where near as loud, you have to listen closely to hear it.
    The temp's here are ok, last night was about 27deg when I tested it.
    Aug 2009
    east anglia
    49
    95
    15
    if i stand correct outdoor unit should be a max of 68 (dba)
    Did you install it or did you get a contractor in ?
    Jan 2010
    Australia
    10
    A contractor installed it.
    From the spec sheet from Daikin's website.
    Outdoor Sound LevelCool (dBA)54/51Heat (dBA)54/51EPA Sound Power LevelOutdoor (dBA)68
    Feb 2009
    Australia
    272
    Its normal,,,,,its a Daikin.
    Jan 2010
    Australia
    10
    It sounds like it's coming from the fan.
    Aug 2009
    east anglia
    49
    95
    15
    Try turning off (power )to outdoor unt and rotate fan by hand to see if catching on something. Pls turn off power first.
    Best thing i think you can do is ask contractor back to investigate. If its a new system should be under warranty, apart from labour!
    May 2006
    Isle of Wight, Uk
    47
    424
    I had a look at an ftxs71 inverter condensing unit the other day, with a sound similar to what you described, turned out to be coming from the main pcb - still works ok just noisy. Apparentley has been noisy for months.
    Andy
    Jan 2010
    Australia
    10
    Quote Originally Posted by Andy AC View Post
    Andy
    Is the sound very loud that you can hear it 15m away?
    Aug 2009
    east anglia
    49
    95
    15
    turn it it off and get contractor back to take alook.
    it shouldnt be that loud.
    regards croc
    May 2006
    Isle of Wight, Uk
    47
    424
    yep, more than 15m
    Jan 2007
    SPAIN
    172
    The whistling sound could well be the PWM switching of the inverters or the mains harmonic filters. Usually this noise level is low and only audible if near the unit. If it is loud then (WITH due respect and care of the DC voltages present) try to find which part is the impertinent noise maker: the compressor, the inductor, or parts of the filters... Then decide what to do! High frequency noise can usually be dampened more easily than low frequencies. Try a used compressor jacket or similar with due care to not touch components, or allow condensation drips to occur on PCBs (a circuit killer).
    Jan 2010
    Australia
    10
    Turns out it was the fan, had it replaced and the noise is gone.
    Aug 2009
    east anglia
    49
    95
    15
    Thanks for the update ctn.
    regards croc
  1. Daikin Split f3 Fault
    By moondawn in forum Air Conditioning
    Last Post: 01-06-2009, 07:09 PM
  2. Daikin split commisioning sheet
    By sexysouthwest in forum Commissioning
    Last Post: 19-01-2009, 09:16 AM
  3. Daikin R410A Split System
    By Testech in forum Heat Pumps
    Last Post: 29-10-2008, 07:32 PM
  4. Daikin split problem (any ideas)
    By airconjohn in forum Air Conditioning
    Last Post: 17-02-2008, 08:40 PM
  5. Daikin twin split
    By Lippygit in forum Trouble Shooting
    Last Post: 28-07-2007, 06:28 PM
