Thread: Daikin uatyp180amy1
11-01-2010, 07:53 PM #1
Daikin uatyp180amy1
hey fellas been working on a system but want to give you fellas a few figures and see what you guys think! Model number as above and on R407c,4.3kg
Heat mode
Discharge pressure=16 bar
Suction pressure=2.5bar
Air on evap= 17.0
Air off evap=30.5
Air on condenser=2
Air off condenser= 0
Temp going into evap=56 deg c
Temp out of evap= 24 deg c
Temp going into expansion valve=24 deg c
Temp out of expansion valve=7 deg c
Temp into condenser=7 deg c
Temp out of condensor= 2 deg c
Suction into compressor= 3 deg c
cooling mode
Discharge pressure=12 bar
Suction pressure=3 bar
Air on evap=18 deg c
Air off evap=6
Air on condenser=20 deg c
Temp going into evap= -2 deg c
Temp out of evap= 5
Temp goin into expansion valve= 27 deg c
Temp out of expansion valve= -2 deg c
Temp into condenser=57 deg c
Temp out of condenser=27 deg c
Suction into compressor=9 deg c
much appreciated
adam
ajj
12-01-2010, 08:31 PM #2
Re: Daikin uatyp180amy1
What do you want to know?
Marc
12-01-2010, 08:58 PM #3
You got a lot of superheat at the comp suction in cooling mode are you sure that the system was in stable operation when you took the measurements
Quidvis Recte Factum Quamvis Humile Praeclarum.
Latine dictum, sit altum videtur.
Si hoc comprehendere potes, gratias age magistro Latinae.
12-01-2010, 11:19 PM #4
13-01-2010, 08:23 PM #5
hi yes the outdoor did have a fan speed controller but was only coming on every 10 secs and then stopping and continue to do so,I thought due to the low head pressure? it was set to the auto position.We have been having problems with this unit with it going off on hp but only on heating? I think possibly an airflow problem. thanks alot
adamLast edited by airconadam; 13-01-2010 at 08:30 PM.
ajj
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Daikin FDYQ250M
By carl in forum Air ConditioningReplies: 7Last Post: 11-08-2009, 12:56 AM -
Daikin AC parts from UK
By skel00 in forum Air ConditioningReplies: 5Last Post: 05-04-2009, 01:24 PM -
Fixing Daikin A3 Error
By Stuffy in forum Air ConditioningReplies: 3Last Post: 27-03-2009, 06:02 AM -
Daikin Comp and inverter
By WCC73 in forum Air ConditioningReplies: 5Last Post: 08-11-2008, 08:44 PM
