View Poll Results: Condensate Removal, Pump Choice
Voters
3. You may not vote on this poll
  • Float operated mini-pumps
    2 66.67%
  • Remote sump pumps
    0 0%
  • Peristaltic pumps
    1 33.33%
    11,025
    on Condensate Removal Methods
    Just a short poll on your preferred method of pumping away condensate from split , wall mounted or cassette, a/c units.
    Gravity is best so there isn't an option for that one
    It's not much but please enter into the spirit of it and fill in the method of your choice. The poll will close in 10 days.
    Thanks, Brian
    manchester
    5,639
    Re: on Condensate Removal Methods
    gravity then mini aqua's or sauermann deltas,
    little giants for cassettes/ducted.
    hydron,sandycott mini pumps too noisy.
    never perisaltics-tubes split,motor grinds,plastic casing cracks,too slow and a pain in the arse correctly fitting the sensors on the universal. sorry to elaborate on your poll.
    May 2006
    Isle of Wight, Uk
    47
    424
    Is a mini/maxi lime classed as gravity? - the water will make its way down to the floor at some point
    Andy
    11,025
    IM, don't apologise, looking at this poll it seems to have failed anyway considering that I said it would end in 10 days and that was 9 years ago
    Comments are always welcomed.
    Came across what I thought was a neat layout the other day. Small pump in a smart casing to fit under wall mounts. I think it was called a mini-white or similar.
    edit: It is a mini-blanc, same thing really...
    http://www.aspenpumps.com/en/mini-blanc.html
  1. Numerical Methods for Engineers and Scientists, Second Edition
    By chillin out in forum Refrigeration Books
    Last Post: 19-05-2010, 04:38 PM
  2. LG condensate
    By gwilliamson in forum Air Conditioning
    Last Post: 10-05-2006, 09:48 PM
  3. 5h Main Bearing Removal And Inserts
    By altaf22m in forum Industrial
    Last Post: 06-03-2006, 09:15 PM
  4. Cooling condenser of split with condensate from evaporator
    By smileypete in forum Air Conditioning
    Last Post: 10-07-2005, 08:21 AM
  5. Removal of migrated oil in dimple plate milk vat
    By Cary in forum Trouble Shooting
    Last Post: 15-05-2004, 05:36 PM
