08-01-2010, 05:01 AM #1
Any Quick Approach to oad calculation
My boss is a little bit rushing recently to get the load estimation for a medium size hospital project.
I 'm looking for a quick method which does not require a bundle of schedule and calculation formula to obtain my loading estimation.
What I have been known so far is using a short cut formula
CFM=(Volume of air conditioned space x 10 ACH)/ 60 min
But I dont know how to go on with this formula to get the required tonage and total loading capacity in BTU/Hr.
08-01-2010, 01:48 PM #2
Re: Any Quick Approach to oad calculation
For a hospital there are no short cuts, do the job properly.
30-01-2010, 03:47 PM #3
For the Hospital project we should keep air change rate 20-25(For Dry Blub temp 22-24dc) then,Your law begin
CFM=(Volume of air conditioned space x 25 ACH)/ 60 min
Here 25-30% fresh air must require of total room supply.Permissible Room noise is 20-25db.
other things are as normal as other projects.Best of the luck.
Quick freeze in brine solultion vs blast freezing seafood??
By lhwang78 in forum CommercialReplies: 9Last Post: 19-06-2010, 04:48 AM -
Quick freezing of fresh products
By maxim971 in forum Technical SpeculationsReplies: 12Last Post: 18-09-2009, 11:06 PM -
Quick Check for Sizing Units to enough Airflow
By udarrell in forum Air ConditioningReplies: 1Last Post: 04-07-2009, 10:49 PM -
NH3 thermosiphon evaporator calculation
By cygbob in forum NH3Replies: 3Last Post: 27-11-2007, 10:00 AM -
Cooling load calculation
By raviperumal in forum Technical DiscussionsReplies: 6Last Post: 02-03-2007, 04:09 AM
