Results 1 to 15 of 15
    MIST HVAC RA's Avatar
    MIST HVAC RA Guest
    water in recovery cylinder
    hi,
    does anybody have a suggestion how to utilize ***** (R-410a) from a recovery cylinder that got some water inside it?
    how to check for water in a ***** cylinder?
    actually, i have plate HX evaporator that leaked and water and refrigerant got mixed. i tried to recover the gas that was inside the system (my mistake) but stopped as soon as i realized it was a bad idea and now i have a contaminated cylinder (not sure).
    Feb 2009
    telford
    2,090
    33
    Re: water in recovery cylinder
    send it for recycling
    MIST HVAC RA Guest
    it means that the cylinder is gone. can't be used?
    any way to fix it?
    Apr 2009
    israel
    778
    Hi there vaccum your cylinder down to 200 micron this should clear out the water but first empty it out completly dont try to vaccum a liter of water!!!
    Multi-vacuum system and break each cycle with oxygen free and moisture free nitrogen, could take a long time, as in 6 > 10 cycles. Time is of the essence. A long time repair.
    The test is monitoring vacuum changes with system isolated and no vac pump operating. There is a glide slope graph to interprute leaks versus moisture over extended periods. I cannot find it so cannot forward. Re-cycle old refrigerant and start with new refrigerant.
    Hopefully you have sorted the problem initially of water in system, otherwise you will go round in circles.
    magoo
    Dec 2009
    Spain
    229
    Why dont you just clean the cylinder and reuse that 410A recycled?
    There is a method to clean any RAC circuit from water, and a cylinder is kind of a small circuit, just one syphon to clean, very simple.
    Oct 2008
    mallorca, spain,
    75
    768
    reclaim the vapour into new reclaim bottle through large dryer gas gone , tip up bottle pour out water heat up bottle 100c vacpump, change oil in vac pump , job done,
    Apr 2009
    israel
    778
    i think after 3 months all the water evaporated!!!
    Oct 2008
    mallorca, spain,
    75
    768
    how can water evaporate in a pressurised bottle mixed with refrigerant?
    Apr 2009
    israel
    778
    Hi sedgY i dont think u got my point ,this thread is 3 months old !!!!!!
    Oct 2003
    5,630
    Goshen, Sedgy's advice was for me the only advice that responded correctly to the original question, no matter if it's 3 months old. Threads in RE are very often consulted for later advise by other members, searching for technical info.
    Oct 2008
    mallorca, spain,
    75
    768
    peter 0ne, thank you for your kind words = so wheres the rep point then ?
    Oct 2003
    5,630
    You're right, sorted out yet
    Oct 2008
    mallorca, spain,
    75
    768
    peter one, thank you for your kind gesture, but I am sure we will agree to have our own ideas?
    and you youngsters will have to put up with us old ones sticking up for what we have allways stood for, fair play and a fair hearing ? thank you.
    yours sedgy,
    Oct 2008
    mallorca, spain,
    75
    768
    hi all just testing, thought it was locked?
  1. Hoshizaki Ice Maker
    By Abe in forum Legal-Business-Marketing
    Last Post: 01-05-2010, 03:27 AM
  2. Fact or Fiction
    By david.findlay in forum Fundamentals
    Last Post: 09-03-2009, 06:19 PM
  3. Modifying aricond. for heating, cooling and hot water
    By kimusabi in forum Technical Discussions
    Last Post: 10-10-2008, 07:28 AM
  4. vacuum in a recovery cylinder?
    By flyboy3b in forum New to RE
    Last Post: 24-09-2007, 09:38 PM
  5. Building a wine cabinet
    By Rory in forum Technical Discussions
    Last Post: 13-07-2004, 08:28 PM
Tags for this Thread
