Thread: Looking for RSU99 replacement
06-01-2005, 07:58 PM #1
Hi guys.
Came across an old AC package controlled by RSU99 made by Stefa Controlls.
Two cooling stages.
Two heating stages.
It was lat so I didnt call anyone to start searching on this side of the world.
Any idea anyone??
Chemi
06-01-2005, 08:36 PM #2
Re: Looking for RSU99 replacement
Hi chemi
Steafa are now under the Seimens umbrella so I did a quick search on their site but unfortunately, the RSU series is not listed. See here http://www.sbt.siemens.com/hvp/staef...=15&ACTION.y=0
Frank
06-01-2005, 08:49 PM #3
Thanks Frank.
I am thinking of installing there a simple temp controller with two stages and a dead zone.
I will look tomorow for something.
Chemi
06-01-2005, 09:01 PM #4
Have a look here Chemi http://frostechnic.com/eliwell.htm
06-01-2005, 09:39 PM #5
We use for such an application the Polygyr from Staeffa, Siemens now.
But I think I know the cards you mean Chemi: is there not a small red button on the front and on the bottom?
If you push it, the alu cover pushes away from the regulator and behind the cover are the switches and potmeters.
The card snaps in a base wit two long bolts with a spring along the bolts.
In the corner of the card you must turn some sort of marker so that it fits in the base just in the right place.
If it's that, then you can use the Polygyr. You can use it anyway for your application. Cost for a Polygyr around 400 € to 450 € I think.
http://www.landisstaefa.com/prd/e/prd_sta_hva_poj.aspIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
06-01-2005, 10:45 PM #6
Just a thought Chemi, is the control actually dead ? Have a look inside under the side cover and check to see if there are still any spare transistors in their holders; if so it might be worth while changing them to see if the beast will restart.
Other than that please give it a decent burial having died at a ripe old ageBrian - Newton Abbot, Devon, UK
07-01-2005, 04:40 AM #7
Thanks guys.
Frank, its a good site, kept it in favorites.
Peter, the one you show, is a different one, we use it in AHU.
its a cooling and heating with two lamps which show cooling or heating demand and a temp dial.
Going out now and among other things, I will start looking.
Chemi
R 417 A direct replacement of R 22
By abbasi in forum RefrigerantsReplies: 28Last Post: 08-09-2011, 12:47 AM -
R502 Replacement.
By Lucas in forum RefrigerantsReplies: 16Last Post: 05-03-2010, 07:11 AM -
Best compressor friendly replacement for R12?
By abcdefg in forum RefrigerantsReplies: 7Last Post: 28-04-2005, 08:23 PM -
R-22 replacement
By shogun7 in forum RefrigerantsReplies: 1Last Post: 26-07-2004, 07:57 AM -
F 11 replacement for flushing
By andrewuk in forum RefrigerantsReplies: 1Last Post: 17-10-2003, 11:03 PM
