Thread: Oil Pump
03-01-2010, 01:43 PM #1
Oil Pump
Can anybody tell me where i can buy an oil pump in the UK? (for pumping oil into compressor), have tried kooltech and they dont stock them, was wondering if anywhere else sells them? Thanks
03-01-2010, 01:48 PM #2
03-01-2010, 01:58 PM #3
Re: Oil Pump
Thanks cadwaladr, but im in newcastle, need to get a hold of one for tomorrow morning if possible!
03-01-2010, 03:36 PM #4
Re: Oil Pump
Dean and Wood, HRP, Climate centre all supply manual oil pumps.
03-01-2010, 03:46 PM #5
Re: Oil Pump
If you can pump it down, you can pull a vacuum on the compressor body with your vac pump and use this to pull some oil in through the oil fill connection and a gauge line.
Its easier if you lines have taps in.
03-01-2010, 03:59 PM #6
Re: Oil Pump
thanks for that, wasnt sure if climate would stock them, good idea monkey if i get stuck getting a hold of one i will try that, cheers
03-01-2010, 10:26 PM #7
Re: Oil Pump
monkey spanners on the money,with the hydroscopic tendencies and the make up of oil nowadays i would steer clear of using a manual pump a charging cylinder is the better solution and can be used for system flushing also
liquid ammonia pump calvitation
By Kathleen in forum Trouble ShootingReplies: 23Last Post: 20-05-2011, 02:18 AM -
Addition of a heat pump to solar heating system
By rt29781 in forum Heat PumpsReplies: 24Last Post: 23-01-2010, 08:46 AM -
Water Pump Tripping Overload. (are you sitting comfortably)?
By Grizzly in forum ElectricalReplies: 14Last Post: 27-08-2008, 08:57 PM -
Troubleshooting a vacuum pump and gauge set.
By Old Codger in forum FundamentalsReplies: 7Last Post: 08-08-2008, 05:13 PM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM
