    Jul 2004
    Scotland
    Help with charge calcs
    Can anyone help with calculating the refrigerant charge for various pipe sizes.
    Initially I thought I knew the procedure when trying to calculate the kg amount for a 1 metre run of 1/2 liquid line (R404a), however my answer indicates I went wrong somewere along the line.
    Oct 2003
    5,630
    34
    Re: Help with charge calcs
    Why do you need to calculate this Dallan?
    I should say, calculate the inner volume and multiply it with the specific mass of the refrigerant at the conditions it passes through the lines.
    But this has nothing to do with refrigeration, this is math.
    Jul 2004
    Scotland
    Thanks for the reply Peter.
    I want to establish a guide per metre of pipe to make ordering refrigerant for larger projects more accurate.
    The main problem is my math is apparently awful.
    What I was looking for was a breakdown of the math steps to see were I am going wrong.
    Jul 2004
    Scotland
    When calculating my charge I am using the density for the relevant refrigerant, for R404a this is around 1000kg/m3. Is this correct.
    Oct 2003
    5,630
    34
    Indeed correct at +/- 23°C for R404a.
    1,01 dm³/kg at 25
    You can find these numbers with Coolpack.
  1. How do I get the charge right
    By Abe in forum Trouble Shooting
    Last Post: 12-12-2007, 02:54 AM
  2. EVAPORATOR CHARGE ---> Questions
    By KETTLER in forum Fundamentals
    Last Post: 14-03-2007, 10:55 PM
  3. Calculating refrigerant charge
    By Consultant in forum Refrigerants
    Last Post: 10-05-2005, 03:39 PM
  4. How do you charge a car A/C
    By dude in forum Air Conditioning
    Last Post: 02-04-2004, 09:36 AM
  5. refrigerant charge
    By pirestani in forum Refrigerants
    Last Post: 02-06-2002, 02:58 PM
