Thread: Pressure drop
Threaded View
29-12-2009, 04:19 PM #2
Re: Pressure drop
There's really no magic way. Installing an access fitting at the evap outlet is the only accurate procedure.
Heatcraft's piping chart list the pressure drop for copper fittings and pipe.
Here's the link to this manual. http://www.hvacrinfo.com/loadcalcs.htm
Just curious, why is there a solenoid valve in the suction line?
To find the pressure drop for the solenoid you will need to get the part number and brand of the valve and look in the manufacturers catalog. Same rule applies for the accumulator. Unless the suction filter has an outlet access fitting, it's a guess.Last edited by powell; 29-12-2009 at 09:23 PM.
Thousands of HVACR manufacturers links! Visit: www.hvacrinfo.com
About liuid line pressure drop.
By wilsoncheung in forum Technical SpeculationsReplies: 15Last Post: 16-03-2009, 11:34 AM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
TEV capacity related to pressure drop
By DaBit in forum CPU OverclockersReplies: 8Last Post: 06-12-2002, 05:11 PM
