Thread: Capillary Tubing
29-12-2009, 02:53 PM #1
Capillary Tubing
Please help with the measurement of the Outside Diameter of .055 Cap Tube. Thanks in advance.
29-12-2009, 03:58 PM #2
Re: Capillary Tubing
I think you'd need a vernier caliper or similar to measure the outside diameter.
If you have an adjustable wrench and some drill bits you could clamp the capiliary with the jaws then try and see which drill fit in the jaws too, then read the size off the drill bit.
29-12-2009, 06:24 PM #3
Ms Has the practical solution.
The link below may Help?
http://www.daycoindustries.com/pdfs/...ary_Tubing.pdf
05-01-2010, 03:18 PM #4
Thanks for link. I have since found the copy of the table I had on file plus another on the web. All 3 are differrent. It would also appear that using the Outside Diameter as a means of determining the Inside Diameter is unreliable as different ID sometimes share the same OD. The final word is find a supplier you can trust and label the Van Stock well!!
02-07-2011, 07:46 AM #5
One poster will post a reply
Then Spammer/spambot copies and pastes for reply, the whole point being their post is JUST to spam links to a website.
Anyone want to sign up for their services? They seem very good to do this and so far be getting away with it. So if you want SEO, click their link I guess
26-11-2011, 11:17 AM #6
Wow..That was really wonderful..Thanks to monkey spanners for his wonderful thought..I could easily find out the outside diameter of the cap tube..Thanks once again..
Small Refrigerator low side tubing
By RLK in forum FundamentalsReplies: 0Last Post: 02-11-2009, 01:07 AM -
Capillary Tube Characteristics
By Chef in forum FundamentalsReplies: 9Last Post: 10-03-2009, 01:03 PM -
Distributor & Capillary tube position
By MrReds in forum Technical DiscussionsReplies: 12Last Post: 29-03-2008, 07:40 AM -
metric capillary tube
By tralex in forum FundamentalsReplies: 5Last Post: 21-02-2006, 06:57 AM -
capillary tubes and mass flow when fed with liquid/gas
By DaBit in forum FundamentalsReplies: 15Last Post: 24-10-2002, 06:52 PM
