    Foobar's Avatar
    Foobar Guest
    Post HA1X hermetic Compressor Analyser
    Just wondering if anyone has a schematic circuit diagram for this unit. I have the manual and data sheet from the manufacturer's website ueitest.com.
    Having opened it up it's probably not beyond the wit of man to trace it out. Just wanted to save some time if someone has already done this / got a diagram. If not will try and post a link to my own offering later.
    11,025
    Re: HA1X hermetic Compressor Analyser
    From an old thread I had found this for an HA1, it may help???
    http://www.ueitest.com/product-ha1.html
    Foobar's Avatar
    Foobar Guest
    Brian, many thanks and apologies for taking so long to reply. The problem with this box seems to be the rating of the switch contacts, especially the Reverse and Start switches when working with larger compressors. I found these had welded over and could not easily locate spares. Eventually I carefully prised them apart and used a magneto file and crocus paper to redress them before rebuilding.
    HAYNES 1st LAW - 'Reassembly is the reverse of the dismantling procedure'
    Mar 2006
    belfast
    239
    you didnt by any chance buy this from ebay, saw one for sale last week
    Nov 2005
    CAIRO
    75
    Brian_UK , thanks for that link to HA1
  1. oil level indication / sample port in hermetic compressor
    By friocold2008 in forum Supermarket Refrigeration
    Last Post: 17-11-2009, 10:30 PM
  2. DC Hermetic Compressors
    By riggsby in forum Air Conditioning
    Last Post: 18-01-2008, 06:19 PM
  3. do we need a hermetic or semi hermetic comp.?
    By duraid in forum Fundamentals
    Last Post: 17-04-2007, 05:52 PM
  4. Hermetic reciprocating versus hermetic scroll
    By Cofreth in forum Technical Discussions
    Last Post: 19-11-2005, 06:29 PM
