24-12-2009, 03:59 AM #1
Compressor Not turning off on defrost
Hoover Fridge/Freezer, 480lt, quite old, orchid range. Recently fitted an Embraco Compressor FG95HAK. When the defrost timer goes into 'DEFROST' mode, evaporator fan turns off but compressor doesnt. I suspect wiring to be wrong. The panel on the compressor has connections labelled L2, L1, N, Earth, in that order. At the moment I have 2 brown lines (one from mains and one from defrost timer) connected to L2. On L1 I have 0ne black line which I suspect is from thermo. Neutral no problem, two blue from mains and timer. I am confident the timer is ok. Gassing should be ok too. She gets cold but the frost and ice build up due to continuous compressor run.
WHAT COULD BE THE PROBLEM???
24-12-2009, 01:23 PM #2
Re: Compressor Not turning off on defrost
24-12-2009, 04:22 PM #3
Welded contact in the defrost timer? (The previous compressor drew exessive el. current).
Defrost settings for Daikin RY100F+ FHYB100
By rdepoort in forum Air ConditioningReplies: 2Last Post: 21-12-2009, 05:38 PM -
Toshiba RAV SM/SP1400 defrost problem
By SteinarN in forum Heat PumpsReplies: 11Last Post: 20-02-2008, 04:25 PM -
No Power for Defrost Timer Motor
By kln in forum DomesticReplies: 6Last Post: 21-01-2008, 08:22 AM -
Hot gas defrost vs Electric defrost
By herdian in forum IndustrialReplies: 19Last Post: 13-08-2007, 11:25 PM
