Thread: Blast freezer
    mkashif's Avatar
    mkashif Guest
    Blast freezer
    Sir,
    I have to install a blast freezer with the following specification:
    Height: 6 Feet
    Width: 10 Feet
    Length: 22 Feet
    2 compressors use 15 Hp each
    2 cooling coils used with 4 fans each
    Gas use R22
    Product : Chicken
    Both cooling coils hang on staring end of the blast freeze (Length)
    Sir, Kindly suggest me that how much time it take to reduce the teperature of the chicken from +15C to -20C.
    Or is it possible that it reduce teperature of chicken from +15 C to -20C in 4 to 6 hours and how.
    Thanking you
    Muhammad Kashif Ilyas
    mkashifilyas@hotmail.com
    Jul 2006
    74
    865
    26
    Re: Blast freezer
    Welcome to the forum mkashif!
    You will need to provide a bit more information such as the total weight of the load and whole or pieces of chicken.
    Do you have the coils and compressors already? If so we would need the specs on them as well.
    Just offhand the two 15HP compressors sound small for that size of blast freezer.
    mkashif's Avatar
    mkashif Guest
    Re: Blast freezer
    Sir,
    Thankyou very much for your reply.
    The total capacity of blast freezer 4000 kg but storing 1000 kg to 3000 kg at a time and chicken store in bunch of pieces of 5kg each.
    We already have cooling coil and compressors. We have 6 feet height of blast freezer and cooling coil installed in a top center of the blast freezer but not effectively maintain air flow after 15 Feet out of 22 Feet Length.
  1. Air blast freezer designation - limited space
    By Sien in forum Industrial
    Last Post: 14-12-2009, 10:13 AM
  2. Blast Freezer Within Freezer
    By rickmor in forum Technical Discussions
    Last Post: 18-06-2009, 03:37 AM
  3. Trolley freezer & blast freezer
    By smpsmp45 in forum NH3
    Last Post: 25-08-2007, 07:29 AM
  4. Blast Freezer
    By w.l.ong in forum Industrial
    Last Post: 16-12-2006, 10:34 AM
  5. Blast Freezer Questions
    By rickmor in forum Industrial
    Last Post: 11-04-2006, 08:15 PM
