Results 1 to 1 of 1
Thread: Mechanical Shaft seal
23-12-2009, 02:52 PM #1
Hi all,
For a development product of a modified compressor I seek a mechanical seal and bearing either as a unit or separate,
General information :
Ambient condition, air at 1 Atm, room temperature.
Fluid R134a.
Shaft top operating speed – 5000 RPM.
Internal chamber operating pressure – 12 to 22 bar.
Internal gas temperature – 70°C.
Shaft diameter – 20 mm.
Outer diameter – can accommodate any diameter up to 60 mm without a problem.
Looking for help on finding vendors for:
1.Bearing, preferred needle roller type, very low load about 200 N
2.Mechanical seal for said shaft.
Howden XRV Shaft Seal Leaking
By Canadian Ice in forum NH3Replies: 29Last Post: 21-03-2010, 02:51 AM -
Help needed in Venezuela.
By El Tel in forum IndustrialReplies: 9Last Post: 15-03-2010, 10:54 PM -
Frick shaft seal leaking
By Ian B in forum Industrial CompressorsReplies: 12Last Post: 27-01-2009, 10:31 PM -
Need info on the shaft seal system for scotsman
By The MG Pony in forum CommercialReplies: 4Last Post: 17-03-2008, 02:02 AM -
Bock AM5 compressor's shaft seal failiure
By Gareth in forum Trouble ShootingReplies: 11Last Post: 05-04-2004, 09:12 PM
