    Dec 2004
    Adelaide, South Australia
    74
    34
    Tech info or direction to for data Mitsubishi RR120 220/240v rotary compressor
    Can any one help with capacity data of this small dometic ?refrigeration compressor at varying suction temps etc etc together current draw.
    Or can any one poinyt me in the right direction.
    Thanks in advance
    Rick
    downunder
    11,024
    Re: Tech info or direction to for data Mitsubishi RR120 220/240v rotary compressor
    Found some info to get you started ??
    Try this link:-
    http://www.refrigerationresearch.com...DC%20power.htm
    data at bottom of screen..
    Dec 2004
    74
    34
    yes I know Brian,,,,but these are the co I am trying to check up on...i dont like what they are trying to say on their site ...ie 240v mitsi rotary (at more than twice the capacity of Danfoss bd35) is less enegy (input watts) than the danfoss for same size cabinet (portable 12volt fridge)
    Oct 2003
    5,630
    34
    Can be correct Eskimo, depends sometimes solely on the conditions they give the capacities.
    And you can't compare a 12 V compressor with a 220 Vac compressor nor different brands.
    Dec 2004
    74
    34
    Peter,
    If I had the tech data of mitsi compressor I can compare it against the 12v Danfoss....
    The fact that one is 12vdc and the other 240v ac 50 or 60 hetz or manufacturer is different does not matter to the capacity of the comp at manufacturers specified conditions.....This is why I need the data so I can compare duty of both
