Results 1 to 20 of 20
    Dhanasekar's Avatar
    Dhanasekar Guest
    Discharge pressure going very high in few seconds
    system dischare pressure is going high and tripping in high discharge pressure with in 30seconds in aircooled chiller so request your help
    Split Croatia
    57
    6,151
    36
    Re: Discharge pressure going very high in few seconds
    Restriction in high side.
    If you provide more data you will get more precise answer.
    Mar 2009
    KZN, South Africa
    64
    2,212
    As Nike said - restriction on HP side. Blocked check-valve?
    Alternatively, if condenser fan stopped - no cooling. We see this in heat-pumps, if the condenser water flow is turned off, for instance.
    Feb 2006
    derbyshire
    610
    has it got a CPR fitted ?[crankcase pressure regulator],if it has try ajusting it to set the back pressure and that will in turn control the discharge pressure.if not fit one,obviousley dont restrict the overhall duty required.
    Feb 2010
    N.Ireland
    stating the obvious but check discharge service valve fully open also that air cooled condenser clear?
    Mar 2010
    56
    5
    nitrogen in system will have this affect
    Mar 2009
    KZN, South Africa
    64
    2,212
    ^ Very much so.
    Oct 2008
    mallorca, spain,
    75
    768
    condencer fans running ? righ way?
    Sep 2003
    ISRAEL
    72
    4,248
    30 seconds is a long time, partially restricted is more likely.
    Too much refrigerant will get you high head pressure.
    you did not supply any details on what your machine does and the operating and control procedure so trying to guess is like playing darts...
    Please try to bring us a better picture of the system.
    Photos always help.
    Mar 2010
    United states
    66
    5
    Chech to see if non condensibles are in the system.
    Feb 2009
    54
    143
    no question is stupid but how can you check if there are non-condesable in the system? Is there a trick, I would like to be enlightend and I am not sarcastic at all, ty.
    Aug 2009
    New Zealand
    2,554
    26
    Quote Originally Posted by Royal241 View Post
    If you have non condensables, they sit in the top of the condenser, stopping flow of the refrigerant to that part of the condenser. So you tend to find that the Top of the condenser is "cooler" than the rest!
    Nov 2005
    New Zealand
    550
    Shut the machine down let it equalize to ambient temp and with P/t chart take readings from gauges should be same as ambient if no non condesibles present
    My wife used to say you never listen to a word I say at least I think that what she said
    Sep 2008
    Newcastle upon tyne
    75
    80
    Another trick with non condensibles is a portable purge unit.
    We have 1 which we put on R123/R11 units to aid purging after nitrogen tests or units purge defective.
    It is suitable to work on most refrigerants and is pre programmed in the software.
    Depends on size of unit and access points available.
    AWW
    Feb 2010
    NT
    66
    15
    More details on the system is better.It could be anything.Restriction,non condensible,lack of air flow etc.
    Mar 2010
    pakistan
    44
    first of all you check your condenser it my be scaled. descaled it from descaler. if your condenser is water cooled then you can applay this mathod.
    Oct 2003
    5,630
    34
    Leave him guys, one of the so many who come here, asks a question and never come back.
    I call this lack of elementary good manners.
    Feb 2010
    NT
    66
    15
    Peter 1.. good one, just leave him guys.
  19. #19
    Oct 2009
    merida mexico
    282
    15
    not operate fans, fan rotation correct?
  20. #20
    Sep 2008
    Canada
    42
    12
    txv too closed on a critical charged system ?
  1. Over charged system... what symptoms?
    By Clk320_Greg in forum Trouble Shooting
    Last Post: 19-10-2009, 06:25 PM
  2. high liquid line pressure?
    By TECH TIM in forum Commercial
    Last Post: 09-05-2009, 05:36 PM
  3. High discharge temp
    By paul_h in forum Air Conditioning
    Last Post: 06-05-2009, 11:10 AM
  4. cooling &freezing comp.
    By afeef in forum Industrial Compressors
    Last Post: 15-12-2006, 09:29 PM
  5. Replies: 6
    Last Post: 18-11-2005, 04:30 PM
