22-12-2009, 11:37 AM #1
Unitary simple packaged system as per TM44
Hello,
I am new to this forum and to Air Conditioning Inspection.
I recently attended a course in Watford for the ABBE Level 3( simple systems) in Air Conditioning Inspection.
In addition to exams etc I also have to submit 3 complete reports for Internal/ External assessment.(In accordance with TM44) I have already undertaken inspections on 2 of the required types. However, I am not able to find / access a 'unitary simple packaged' system i.e. Sometimes described as a through the wall unit / window wrapper etc.
For this inspection I’ll require photos, measurements/plans for the room it serves, any defects and so on.
If anyone can either help with this or advice how I may go about trying to locate a through the wall unit for Inspection - This would indeed be appreciated
Thank You
22-12-2009, 12:08 PM #2
Re: Unitary simple packaged system as per TM44
Hi Simon and welcome to the forum.
I would suggest that you keep your eye on the walls and windows in your local area to see if you can find one.
Also some industrial buildings often had them fitted to cool down small spaces.Brian - Newton Abbot, Devon, UK
22-12-2009, 12:34 PM #3
Thanks for that - I'll keep a particular eye out for Industrial buildings as so far i have had no luck
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 10:09 PM -
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 12:39 PM -
What is System balance?
By shogun7 in forum Technical SpeculationsReplies: 56Last Post: 19-01-2006, 09:47 AM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM -
Automotive A/C Vent Temp Range vs System
By Don Browney in forum Air ConditioningReplies: 1Last Post: 15-05-2002, 06:19 AM
