Thread: rticle copper corrosion of coils
20-12-2009, 01:36 PM #1
20-12-2009, 01:39 PM #2
Re: Article copper corrosion of coils
20-12-2009, 01:43 PM #3
Found all this while searching for information about copper corrosion. 2 cases I have for the moment: 1 piece of +/- 15 cm (7 inch) Armaflex isolated 1 3/8 pipe of a Daikin VRV, installed underground but in a seamless PVC sleeve, no water in the sleeve and +/- 50 leaks on it.
Another case: 2 independent evaporators in a ventilated counter and +/- both have leaks on 1 piece of +/- 10 cm (+/- 5 inch) 1/2 tube, sometimes 100 leaks on this end.
No agresive cleaning agents used, only twice a year cleaned with drinkable water.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
20-12-2009, 02:10 PM #4
Brazing movies
http://www.errachidia.org/tv/1-brazing.html
Good brazing moviesIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
20-12-2009, 07:51 PM #5
Re: rticle copper corrosion of coils
Very interesting Peter. Thanks for the links.
20-12-2009, 08:36 PM #6
You can always blame Global Warming......
Seriously, I have seen galvanised steel pipes wrapped with PVC isolation tapes and was told that it prevents all kinds of external corrosion.
Maybe it worth trying.
joining copper to copper, joining copper to brass
By mac_J in forum Technical DiscussionsReplies: 9Last Post: 15-01-2008, 02:29 AM -
Dynalene & Corroding Copper Coils?
By mecassa in forum Supermarket RefrigerationReplies: 4Last Post: 19-06-2007, 10:43 PM -
Copper tube degreasing specification
By Thermatech in forum Technical DiscussionsReplies: 2Last Post: 23-05-2007, 03:10 PM -
Will iron rich water attack copper & s/steel?
By garyb in forum Trouble ShootingReplies: 1Last Post: 14-02-2006, 03:55 PM -
Corrosion.
By romaurie in forum IndustrialReplies: 4Last Post: 27-11-2005, 10:57 PM
