    Trevor1's Avatar
    Trevor1 Guest
    Quantum LX Control Panel
    Hello everyone. Just wondering if anybody has had a problem with the screen on a Quantum LX control panel, mounted on a Frick screw compressor? Three days ago the panel went completely black. The panel was installed about six months ago, is still on warranty but the closest service man (Cimco) is two hours away
    Jul 2009
    arkansas
    42
    Re: Quantum LX Control Panel
    Check the white cable running from the processor baord to the LED display, it is white and on the right side. It comes undone sometimes. If thats not the problem check the power supply for the Display, this is mounted on the inside of the white panel behinde the display at the top left hand side. Watch out thought because it uses 120vac instead of 5vdc. If those dont fix the problem then its the display power supply and you will have to order another one and of course check all the connections. Also its a good idea to check the main power suplly it should be between 5.15-5.23 vdc. The IOM or Quantum service manual will tell you home to do this.
    Mar 2010
    ohio
    21
    make sure from each sub board that a sensor not pulling all the power and going into i/o com failure. the power pack does adjust voltage also.min voltage 4.9vdc too much will fry boards.
  1. Bosch Fridge Freezer Control Panel Problem
    By Bork in forum Domestic
    Last Post: 25-08-2009, 01:02 AM
  2. Wrong temperature on control panel
    By swee'pea in forum Trouble Shooting
    Last Post: 14-01-2009, 09:18 AM
  3. Frick Quantum LX Compressor control panel: Capacity Control Screen
    By screw_geek in forum Industrial Compressors
    Last Post: 15-06-2008, 06:47 AM
  4. Frick Quantum Panel
    By LEE40 in forum Trouble Shooting
    Last Post: 27-03-2008, 05:24 PM
  5. Whirlpool 20RI D3 Control Panel Problem
    By broadmate2003 in forum Trouble Shooting
    Last Post: 27-01-2008, 09:17 PM
