Thread: R134a pressures please
14-12-2009, 12:27 PM #1
Hi this is my first thread so please bear with me, does any one know the expected running pressures of a freezer running on R134a, we are just about to fit the new condenser replacing the old R12 prestcold existing, my experience with refrigeration dates back to R502,R12 days so any help will be welcomed.as far as i can tell the system would run at low pressure or even a vacuume. i do know that 404a would be better but do not have the ability to change all the valves etc as its a bespoke freezer for a well known fast food chain.
14-12-2009, 01:09 PM #2
Re: R134a pressures please
0 deg C = 2 barg (27 psi)
-5 = 1.45 barg (20 psi)
-10 = 1 barg (14 psi)
-15 = 0.65 barg (9 psi)
-20 = 0.35 barg (4 psi)
-25 = 0.1 barg (less than 1 psi)
-30 = -0.2 barg (-3 psi) (I know there is no such thing as a negative pressure but I just read it off the compariter).
Just be aware that to get the evap temp you need you have to run a very low back pressure.
Cheers taz.
.Last edited by taz24; 14-12-2009 at 01:17 PM.
14-12-2009, 02:11 PM #3
Thanks very much very helpfull
14-12-2009, 02:15 PM #4
14-12-2009, 02:42 PM #5
Would a drop in not be better? Like ISCEON49?
R507 in an R134a compressor: any danger?
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 21-12-2009, 12:44 AM -
R134a operating pressures
By chillymatt in forum FundamentalsReplies: 6Last Post: 08-05-2008, 09:31 PM -
Pressure Transmitter R134a Setpoints
By cooltrain in forum Technical SpeculationsReplies: 0Last Post: 28-02-2005, 09:05 AM -
Is there anything about R134a that is better than R12?
By dude in forum RefrigerantsReplies: 5Last Post: 01-03-2004, 09:59 PM
