Results 1 to 2 of 2
Thread: air cooled condenser design
23-12-2004, 01:26 PM #1
i will be most greatful if any body can tell me how air cooled condenser is designed?
information should include b
no of fins
no of rows
face ara?
dont worry about heat of rejection. i know about it
waitin 4 reply
Our nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
26-03-2005, 08:33 PM #2
Re: air cooled condenser design
The design of an air cooled condenser is somewhat complicated and not easily done in on short equation. You have to first determine the circuiting and tube pressure drop which is limited by Reynolds Number for good heat transfer. The circuiting and flow have an effect on the inside heat transfer coefficients. The heat transfer rate and data is changing all along the tube since we start with a dry tube and progress to a wetted tube and a changing two phase flow. The heat transfer rates also differ with the refrigerant. Then you have to consider the air side performance which is controlled by the extended heat transfer area (no of fins, tube pitch), number of tubes (prime heat transfer surface) and the air volume. The fine type can be flat, waffle type or lanced. There are volumes written on air exchanger heat transfer design.
Ken
Air Cooled Condenser Design
By Samarjit Sen in forum Technical DiscussionsReplies: 7Last Post: 23-06-2011, 12:54 PM -
method to design air cooled condenser
By abbasi in forum New TechnologiesReplies: 4Last Post: 12-02-2008, 08:34 AM -
How to adjust head on a water cooled condenser
By kengineering in forum Technical SpeculationsReplies: 5Last Post: 30-05-2007, 10:37 PM -
water cooled condenser shell type
By abbasi in forum New TechnologiesReplies: 0Last Post: 27-04-2005, 08:32 AM -
Trane Air cooled condenser
By jan behnke in forum Trouble ShootingReplies: 24Last Post: 05-08-2004, 07:31 AM
