Thread: lennox outdoor unit icing up
13-12-2009, 07:09 AM #1
my serviceman keeps adding more & more on the repair costs..defrost board outside, then thansformer, then time delay board,..can all these be defective at the same time, but the heat-pump still works, till it freezes up outside?
Service guy wants to charge 700 bucks to change the aboves, I feel cheated, what should I do, is it something I can do myself?
13-12-2009, 08:47 AM #2
Re: lennox outdoor unit icing up
i think he is playing safe, with all those parts, but i suspect the defrost board, dont pay him untill its fixed,
if you cant't fix it don't
Lennox unit head pressure control
By marc5180 in forum Air ConditioningReplies: 5Last Post: 20-06-2009, 11:29 PM -
Lennox unit problem
By marc5180 in forum Air ConditioningReplies: 35Last Post: 08-11-2008, 11:16 PM -
Outdoor coil icing up...
By airflo in forum Heat PumpsReplies: 18Last Post: 28-10-2008, 08:12 PM -
lennox fault code
By richelli in forum Trouble ShootingReplies: 0Last Post: 01-02-2008, 10:13 PM -
What causes the icing of the evaporator
By donrtc in forum Technical DiscussionsReplies: 12Last Post: 19-08-2005, 12:35 PM
