Results 1 to 2 of 2
    lenboy's Avatar
    lenboy Guest
    Talking lennox outdoor unit icing up
    my serviceman keeps adding more & more on the repair costs..defrost board outside, then thansformer, then time delay board,..can all these be defective at the same time, but the heat-pump still works, till it freezes up outside?
    Service guy wants to charge 700 bucks to change the aboves, I feel cheated, what should I do, is it something I can do myself?
    Mar 2006
    92
    13
    Re: lennox outdoor unit icing up
    i think he is playing safe, with all those parts, but i suspect the defrost board, dont pay him untill its fixed,
    if you cant't fix it don't
  1. Lennox unit head pressure control
    By marc5180 in forum Air Conditioning
    Last Post: 20-06-2009, 11:29 PM
  2. Lennox unit problem
    Last Post: 08-11-2008, 10:16 PM
  3. Outdoor coil icing up...
    By airflo in forum Heat Pumps
    Last Post: 28-10-2008, 07:12 PM
  4. lennox fault code
    By richelli in forum Trouble Shooting
    Last Post: 01-02-2008, 09:13 PM
  5. What causes the icing of the evaporator
    By donrtc in forum Technical Discussions
    Last Post: 19-08-2005, 12:35 PM
