    Aug 2009
    Manchester
    29
    Maneurop, Copeland, Performer compressors
    If there is any one out there that has any connection to Maneurop, copeland, performer etc could you please make a recomendation that carrying handles be fitted onto these compressors, im sure it wouldnt cost the earth to do and would certainly make the engineers job alot easier when carrying them
    3,856
    Re: Maneurop, Copeland, Performer compressors
    They are tricky things to lift and carry aren't they. There is a carry handle available (forget who makes it) that makes use of the lifting eye these comps have welded to the top, it hooks in, provides a handle in the centre above the comp and has a steadying bar that goes down the side of the comp.
    May be worth getting one if you change a lot of compressors.
    Jan 2008
    49
    82
    For copelands and prestcolds always had some long bolts in my toolbox to fit into the body to act as handles. As for maneurops bear hug and grunt or theres always the special tool.............. the apprentice!!!
    colin smith's Avatar
    colin smith Guest
    i am looking for a simple calculator for working out equipment size for cold rooms
    Aug 2009
    Manchester
    29
    cheers guys i do use a "make shift tools" id like to use the apprentice but he can just about lift his butty box
  1. Suniso 3GS instead of Maneurop white oil 160P
    By nike123 in forum Air Conditioning
    Last Post: 01-11-2010, 05:42 AM
  2. Maneurop ntz compressors
    By chemi-cool in forum Commercial
    Last Post: 22-10-2009, 10:06 PM
  3. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  4. Do we have some expert in replacing compressors
    By Zahid in forum Air Conditioning
    Last Post: 01-07-2008, 07:59 AM
