Thread: Drain plug fittings
11-12-2009, 04:28 PM #1
Drain plug fittings
Hi,anyone know of a supplier for condensate drain plug fittings for out door units.I need a couple for LG split units but they are not available as a spare,would any other makes fit?,have an idea of glueing in a flared tube if I can't get one.
11-12-2009, 05:01 PM #2
Re: Drain plug fittings
You could try a 3/4" overflow tank connector, may need to make the holes a bit bigger in the unit or fit one of those drip pans.
11-12-2009, 05:05 PM #3
Thanks,could use my tank/cone drill to open up.
fusible plug on absorption cooling unit
By Marco Jiang in forum Technical DiscussionsReplies: 5Last Post: 03-07-2010, 08:48 AM -
Use of Copper Fittings
By Waqas Ahmad in forum Air ConditioningReplies: 2Last Post: 13-07-2009, 04:33 AM -
Fujitsu Split A/C wall unit condensation drain tube
By Cool 'and Luke in forum Air ConditioningReplies: 12Last Post: 21-08-2008, 08:55 AM -
Drain Vavle / PR safety vavle for the receiver.
By smpsmp45 in forum NH3Replies: 7Last Post: 23-06-2008, 04:42 PM -
condensation on drain line
By LRAC in forum Air ConditioningReplies: 5Last Post: 21-09-2006, 04:05 PM
