Results 1 to 8 of 8
    Oct 2009
    Philippines
    Question Ammonia Sensors and Alarm
    I wanted to install ammonia sensor and alarm system for a cold storage facility. However, it seems there are so many types to choose from. It seems there are electro-chemical, opto-acoustic, infrared, semi-conductor, explosimeter types. Can someone help me as to the difference between them and what they found to be the better ones based on their experience ?
    The system we are using in another location is a Cool-Air model LBW-50. Just wanted to find out more first rather than just duplicate the system.
    I'm new to the forum and not quite if this is the correct place to put it. So apologies if it is not in the right place.
    3,357
    Re: Ammonia Sensors and Alarm
    Cool air is good and resonable price , reliable .
    Oct 2009
    Philippines
    Thanks very much for your input, Ranger1.
    What about Chillgard ammonia gas monitor ? Has anyone used these before ? Any good ?
    I noticed one say it has a Metal oxide semiconductor sensor while the other says it is electrochemical sensing. I'm confused as to what is the difference and which is better in certain applications
    3,357
    Try Danfoss site , it may have info on what you require .
    Mar 2010
    UTAH
    I think you should go for Cool Air Lbw-420, because it has the Detection Sensitivity up to 1000 ppm. Moreover , Coll air detectors have metal oxide semiconductors too.
    ________________________________
    Commercial Refrigerator
    Oct 2009
    Philippines
    Yeah, I did finally went for Cool-Air. Thank you.
    Apr 2009
    TEXAS
    49
    28
    I would only use an electrochemical sensor in areas set to be constantly occupied by personnel. The PEL limit for ammonia is 50ppm and the detection has to be reliable below 50ppm. Your first warning should be at 25-35ppm to allow time to evauate the area. Solid state sensors are not as reliable below 50ppm. Solid state is susceptible to spices, vapors, and other gases which could cause a false reading. Honeywell who bought manning, Gfg, CTI, and Draeger are probably the most widely used in the industry for electrochemical. Infrared are expensive and not good for the lower concentrations yet, but have potential.
    Jun 2007
    South Africa
    66
    120
    Google the Murco website. Pricey but still the best.
    I am not always right, but I'm never wrong!
  1. Carrier Transicold Container Problem
    By Shamel in forum Transport
    Last Post: 23-01-2012, 11:23 PM
  2. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  3. Ammonia Containment
    By AndrewU in forum NH3
    Last Post: 18-03-2010, 11:53 PM
  4. TK alarm 12
    By Fridgevan irela in forum Transport
    Last Post: 30-10-2009, 01:51 PM
  5. Thermo King SBIII Alarm Code 29???
    By ppodsiadlo in forum Transport
    Last Post: 31-12-2008, 10:04 PM
