10-12-2009, 08:42 PM #1
problem with AUX ASW-H18B4/HSAR air coditioner
Hi.I have a problem with an AUX ASW-H18B4/HSAR air conditioner.It does not start and flashes an error code E3.Does anyone knows what this means?Thanks.
10-12-2009, 09:03 PM #2
Re: problem with AUX ASW-H18B4/HSAR air coditioner
E3 srror on the AUX smaller units is evaporator sensor fault, I would think this will be the same for larger units.
11-12-2009, 01:59 PM #3
Thanks.I will have this sensor chacked.You have been very helpfull.
22-12-2009, 09:56 PM #4
22-12-2009, 11:11 PM #5
Thank you for the update.
24-07-2011, 03:43 PM #6
hi i have the same problem with an Aux airconditioner AS-H12A4/HSR 407c ...it is giving error E3.. i know it means the evaporator sennsor is gone but can you help me find the correct sensor since i cannot find one at a local shop here in gozo..does anyone has the part number for it or better a link so that i can buy it online..since i need to repair it for a friend of myn as soon as possible
thanks
MFI AMP6855 defrost problem
By gliderpilot47 in forum DomesticReplies: 4Last Post: 12-01-2011, 12:11 PM -
problem with GE air con power problem
By Richie101 in forum Air ConditioningReplies: 6Last Post: 05-11-2009, 04:00 PM -
Samsung Vivace Problem AQV24VBCN
By goldpau in forum Air ConditioningReplies: 0Last Post: 18-09-2009, 06:28 PM -
Saunier Duval Problem
By mallorcanangel in forum Air ConditioningReplies: 1Last Post: 10-07-2009, 01:26 AM -
Furance problem
By ALONEI in forum Trouble ShootingReplies: 10Last Post: 14-05-2008, 11:32 AM
