Thread: Mouse instruction not responding
10-12-2009, 04:02 AM #1
Hi everybody,
Could you help me please? I have problem with my notebook HP540 core2duo. OS windows XP SP2.
After startup, mouse was not responded by computer. Then I run task manager by CTRL ALT DEL. Result is OK. Mouse normally.
Then I opened program applications this problem accour again.
To solve it, mouse "KLIK" out side of application screen then KLIK back in application, mouse normaly again. This happen again and again.
I suspected virus attack but can' clean by virus cleaner and removal. Then try reformat the hard disk and reinstall the windows but the same problem stiil happen.
I don't think that any hardware damage.
B Rgds
Teguh
10-12-2009, 05:28 PM #2
Re: Mouse instruction not responding
Try another mouse. Try plugging in a different USB port if that's what you have. Sonds like a broken wire or bad connection as you move the mouse.
12-12-2009, 04:19 AM #3
Hi Robe,
I have done it but not improve. I certainly that mouse or port are good order. Is it possible any improper working of driver? Because when reinstalled the driver I took from copied driver. Maybe it has to be installed from CD.
I have not tried yet.
12-12-2009, 05:03 PM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Find driver on internet page of mouse manufacturer and install it after you first uninstall old driver.
Then install Hijackthis software and run scan and save log.
After that upload scan log to this page and see what is marked red.
16-12-2009, 04:44 AM #5
Hi Nike,
I have done as your guidence.
Reformat disk and reinstall again the windows and all driver was downloaded from HP web. Performance is good and improve without use mouse. unfortunately, After installed mouse, the same problem occur again ( i use plug and ply mouse ). Then I went to hijackThis as below and analyze the log scan, there is not any problem. All are in safe.
16-12-2009, 07:07 AM #6
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
YORK YCUM YCAM Controller (maybe Millenium) Instruction (Manual) required
By Jacek in forum Refrigeration BooksReplies: 20Last Post: 15-08-2010, 11:49 AM
