    Sep 2008
    U.S.A.
    68
    7
    Ground loop antifreeze
    Hi Folks, I have been following the debate about proper antifreeze for the ground loops of a ground coupled heat pump.
    Does anyone have experience with using Sierra automotive antifreeze?
    I have read that you shouldn't use automotive antifreeze, but I am not sure if that was because "standard" automotive antifreeze is usually ethylene glycol as opposed to the Sierra which is propylene glycol?
    Any thoughts or opinions?
    Thanks, Dave
    11,024
    Re: Ground loop antifreeze
    This taken from the Engineering Toolbox...
    Ethylene glycol should be avoided if there is a slightest chance of leakage to potable water or food processing systems. Instead solutions based on propylene glycol are commonly used.
    So it seems there is a potential contamination threat to be avoided.
    http://www.engineeringtoolbox.com/et...col-d_146.html
    Sep 2008
    U.S.A.
    68
    7
    Quote: Ethylene glycol should be avoided if there is a slightest chance of leakage to potable water or food processing systems. Instead solutions based on propylene glycol are commonly used. .................................................................................................... .......................................... So it seems there is a potential contamination threat to be avoided.
    Hi Brian, that was one of my reasons for the question. The Sierra brand automotive antifreeze HAS a propylene glycol base as indicated in my initial post. Dave
    Mar 2009
    KZN, South Africa
    64
    2,212
    Interesting thread. Thanks for the information BM & Brian.
    11,024
    Yes, I suppose that you have to consider the result of a leak into you local groundwater area.
    Not something that you plan for but things do bite you in the ass some times
    Jun 2006
    British West Indies
    543
    propylene gets hard to pump if you need the lower freeze protection temps.
    Alcohols are common such as ethanol, methanol. Easier to pump.
    You need to see what is allowable in your area.
    I have never seen ethylene glycol ever allowed to be used in ground loops
    Take the V out of HVAC and you are left with a HAC job
  1. Replies: 24
    Last Post: 17-01-2009, 01:22 PM
  2. Greenline ground loop heat pump
    By Chris2005 in forum Heat Pumps
    Last Post: 22-10-2008, 11:32 AM
  3. Ground source or air source heat pumps?
    By Karl Hofmann in forum New Technologies
    Last Post: 20-08-2008, 05:23 PM
  4. Chilled Water A/C System.. antifreeze or no?
    By WangFu in forum Technical Speculations
    Last Post: 09-08-2007, 10:36 AM
  5. Geothermal ground loop-multiple source/sink
    By bvis in forum New Technologies
    Last Post: 15-03-2006, 10:27 PM
