Results 1 to 2 of 2
Thread: New Trane xl14c HP question
03-12-2009, 09:11 PM #1
I just had a new Trane xl14c 2.5 ton heatpump installed. I like it so far except for one thing, the fan only setting gives me 50% fan speed. Installer says there in no way to change this. I would like it to run at 100% fan speed in fan only setting to circulate the air in the house. Is the installer correct or does he just not want to be bothered with it since he has his money?
12-01-2010, 04:51 AM #2
Re: New Trane xl14c HP question
yes you can make it a single speed unit if you choose to just make sure you eliminate the low speed wire and addanother section of wire from that relay to your high speed tap and thus you have a single speed moter now.
AEC Pinical chiller with trane comp
By cptrdbrd in forum CommercialReplies: 1Last Post: 28-10-2009, 09:47 PM -
trane ertaa213 EEV fault (1AA)
By knight rider in forum Technical DiscussionsReplies: 4Last Post: 11-06-2009, 06:40 AM -
Pretty Hard Question about calculating a vacuum.....help
By halfcan in forum TrainingReplies: 1Last Post: 02-06-2009, 04:01 PM -
Refriferation cycle question
By ozmecheng in forum FundamentalsReplies: 32Last Post: 26-03-2008, 10:38 PM -
Tow question for trane ciller cxan m600
By anesti in forum Air ConditioningReplies: 9Last Post: 22-01-2008, 02:48 PM
