Threaded View
02-12-2009, 03:57 PM #2
Re: So Low Ultra low frezeer retrofit
hi there, the problem you will have possibly is the capillary lines as they might required to be changed for the retrofitting. i will have a look in my service manuals and get back to you with the capillary sizes and length and give that a try. for the oil i use as standard mobil eal arctic 22 it is a very good oil to use in the second stage. hope this helps
Ultra low Temp Refrigeration
By elmusasc in forum IndustrialReplies: 5Last Post: 31-07-2011, 07:00 PM -
Retrofit from R-22 to R134a on York YS.
By sean in forum RefrigerantsReplies: 0Last Post: 25-11-2009, 04:22 PM -
R22 retrofit
By Leo1967 in forum Legal-Business-MarketingReplies: 10Last Post: 27-04-2009, 12:36 PM -
retrofit
By AIRTECH222 in forum RefrigerantsReplies: 4Last Post: 08-04-2009, 09:17 PM
